查看: 837|回复: 0
[评测分享] 【创龙科技TLZ7x-EasyEVM-S评估板试用】之二:体验ZYNQ下linux
  • 签到天数: 4 天
    发表于 2022-8-19 19:16:15 | 显示全部楼层 |阅读模式
    开发板自带linux系统,上电:
    启动过程:
    进行linux命令测试:
    1. PetaLinux 2017.4 Zynq-Tronlong ttyPS0
    2. Zynq-Tronlong login: root (automatic login)
    3. root@Zynq-Tronlong:~# cd ..
    4. root@Zynq-Tronlong:/home# ls
    5. root
    6. root@Zynq-Tronlong:/home# cd ..
    7. root@Zynq-Tronlong:/# cd ..
    8. root@Zynq-Tronlong:/# ls
    9. bin  boot  dev  etc  home  lib  lost+found  media  mnt  opt  proc  run  sbin  sys  tmp  usr  var  www
    10. root@Zynq-Tronlong:/# df -h
    11. Filesystem      Size  Used Avail Use% Mounted on
    12. /dev/root       5.8G  734M  4.7G  14% /
    13. devtmpfs        170M  4.0K  170M   1% /dev
    14. tmpfs            40K     0   40K   0% /mnt/.psplash
    15. tmpfs           194M  128K  194M   1% /run
    16. tmpfs           194M   40K  194M   1% /var/volatile
    17. /dev/mmcblk0p3  5.8G  734M  4.7G  14% /run/media/mmcblk0p3
    18. /dev/mmcblk0p1  3.0G  620K  3.0G   1% /run/media/mmcblk0p1
    19. /dev/mmcblk1p1  124M   512  124M   1% /run/media/mmcblk1p1
    20. /dev/mmcblk1p3  1.4G  2.2M  1.3G   1% /run/media/mmcblk1p3
    21. /dev/mmcblk1p2  2.0G  727M  1.2G  39% /run/media/mmcblk1p2
    22. root@Zynq-Tronlong:/# uname -a
    23. Linux Zynq-Tronlong 4.9.0-rt1-xilinx-g57b87eb #1 SMP PREEMPT Fri Oct 15 13:59:45 CST 2021 armv7l armv7l armv7l GNU/Linux
    24. root@Zynq-Tronlong:/# cat /etc/issue
    25. PetaLinux 2017.4 \n \l
    26. root@Zynq-Tronlong:/# cat /proc/cpuinfo | grep name | cut -f2 -d: | uniq -c
    27.       2  ARMv7 Processor rev 0 (v7l)
    28. root@Zynq-Tronlong:/# cat /proc/cpuinfo | grep physical | uniq -c
    29. root@Zynq-Tronlong:/# getconf LONG_BIT
    30. 32
    31. root@Zynq-Tronlong:/# lscpu
    32. -sh: lscpu: command not found
    33. root@Zynq-Tronlong:/# cat /proc/cpuinfo
    34. processor       : 0
    35. model name      : ARMv7 Processor rev 0 (v7l)
    36. BogoMIPS        : 666.66
    37. Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
    38. CPU implementer : 0x41
    39. CPU architecture: 7
    40. CPU variant     : 0x3
    41. CPU part        : 0xc09
    42. CPU revision    : 0
    43. processor       : 1
    44. model name      : ARMv7 Processor rev 0 (v7l)
    45. BogoMIPS        : 666.66
    46. Features        : half thumb fastmult vfp edsp neon vfpv3 tls vfpd32
    47. CPU implementer : 0x41
    48. CPU architecture: 7
    49. CPU variant     : 0x3
    50. CPU part        : 0xc09
    51. CPU revision    : 0
    52. Hardware        : Xilinx Zynq Platform
    53. Revision        : 0003
    54. Serial          : 0000000000000000
    55. root@Zynq-Tronlong:/#
    GMT+8, 2025-1-12 06:58 , Processed in 0.114719 second(s), 17 queries , MemCache On.
