查看: 246|回复: 0
[经验] 消除电荷泵中的电流不匹配
发表于 2022-8-17 09:43:24 | 显示全部楼层 |阅读模式
Conventional CMOS charge-pump circuits havesome current mismatch problems. The current mismatch induces a phase offset which deteriorates the performance of Up PLLs or DLLs. This paper investigates causes of current mismatch of conventional CMOS charge-pump and proposes new charge-pump circuits to reduce the current mismatch. The Vpb DLL with proposed charge-pump is simulated in a 0.18 um CMOS process.
01693061.pdf
3.73 MB, 下载次数: 0
GMT+8, 2024-11-24 18:57 , Processed in 0.107758 second(s), 16 queries , MemCache On.
