查看: 207|回复: 0
打印 上一主题 下一主题
[经验] Generalized WLS Method for Designing Allpass Variable Fractional-Delay Digita...
跳转到指定楼层
楼主
发表于 2022-8-10 11:30:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract— This paper presents an optimal weighted-leastsquares (WLS) method for designing low-complexity allpass variable fractional-delay (VFD) digital filters. Instead of using a fixed range for the VFD parameter p and same-order constantcoefficient filters (subfilters), both the VFD parameter range p ∈ [pMin, pMax] and subfilter orders are optimized such that a low-complexity allpass VFD filter can be achieved for the leastsquares (LS) design. To suppress the peak errors of variable frequency response, weighting functions are adopted and optimized such that the boundary peak errors can be further reduced but without noticeably increasing the total error energy (integral of squared error) of variable frequency response. After optimizing the variable range of the VFD parameter, weighting functions, and subfilter orders, an allpass VFD filter can be designed by using a generalized noniterative WLS method, which yields a closed-form solution. Design examples are given to illustrate that utilizing different-order subfilters along with the optimal range and optimal weighting functions can yield an allpass VFD filter with signifiantly reduced complexity and design errors as compared with the existing ones.
Generalized WLS Method for Designing Allpass Variable Fractional-Delay Digital Filters.pdf
1.34 MB, 下载次数: 0
举报
站长推荐上一条 3/5 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-30 08:37 , Processed in 0.138171 second(s), 18 queries , MemCache On.
