查看: 220|回复: 0
[经验] A 900 MHz integrated Discrete-Time Filtering RF RF Front-End
发表于 2022-8-10 11:24:45 | 显示全部楼层 |阅读模式
Power, size, and cost are primary design considerations in radio receivers used for portable communications. Unfortunately, superheterodyne IC receivers require discrete tuned-circuits that consume valuable board space and dissipate significant amounts
of power. Direct conversion receivers are an alternative to the superheterodyne receiver architecture [l]. However, in such receivers severe LO to RF leakage limits the achievable dynamic range [2]. Front-end A/D conversion is rarely a viable option because of its limited resolution and excessive power dissipation at high conversion rates
A 900 MHz integrated Discrete-Time Filtering RF RF Front-End.pdf
1.09 MB, 下载次数: 0
GMT+8, 2024-11-24 18:47 , Processed in 0.104699 second(s), 16 queries , MemCache On.
