查看: 259|回复: 0
[经验] Circuit Design for RF Transceivers
发表于 2022-8-6 15:43:27 | 显示全部楼层 |阅读模式
One of the key parts in a mobile telecommunication tenninal is the transceiver. The tenn transceiver stems from the words transmitter and receiver. These words refer to the main task of a transceiver. In the context of a mobile telecommunication tenninal, the receiver transfonns the signals coming from the antenna into signals which can then be converted into the digital domain. The
transmitter converts the analog version of the digital data stream at baseband into a signal at radio frequencies, and delivers this signal to the antenna with a certain amount of power.
Circuit Design for RF Transceivers.pdf
11.24 MB, 下载次数: 2
GMT+8, 2024-11-24 21:01 , Processed in 0.105586 second(s), 16 queries , MemCache On.
