查看: 354|回复: 0
打印 上一主题 下一主题
[经验] A 1V power supply operation CMOS subbandgap reference using switched capacitors
跳转到指定楼层
楼主
发表于 2022-8-6 12:53:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract—In this paper, a 1V supply voltage CMOS subbandgap reference is proposed and implemented. The proposed circuit, based on voltage signals, averages two voltages with opposite dependence on temperature to cancel the temperature dependence and generates reference voltage. The average circuit uses switched capacitor techniques to reduce the chip area. This proposed circuit has been implemented in a standard 0.35µm 1P4M CMOS process. The active area of this circuit is 762µm×283µm. The experimental results show this designed circuit work properly with minimum supply voltage of 1V. The generated reference voltage VREF is 0.640V, under 1V power supply at room temperature and a 26mV output voltage variation for the temperature range from -10͠ to 60͠. The power dissipation of this circuit is 74µW.
A 1V power supply operation CMOS subbandgap reference using switched capacitors.pdf
203.27 KB, 下载次数: 0
举报
站长推荐上一条 2/5 下一条
「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
查看 »
GMT+8, 2025-4-30 08:53 , Processed in 0.109841 second(s), 18 queries , MemCache On.
