查看: 331|回复: 0
打印 上一主题 下一主题
[经验] A 1V MNC Bandgap Reference with High Temperature Stability
跳转到指定楼层
楼主
发表于 2022-8-6 12:51:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract-A 1V matched nonlinear correction (MNC) CMOS bandgap reference is presented in this paper. A 1V operational amplifier (OPA) with rail-to-rail input signal swing is also applied in the reference circuit. According to the simulation results, the output voltage is 353.12mv and there is only ±0.4mv variation from the range of -20°C to 100°C. The power dissipation of the circuit is 0.16mW, and the area is 0.1mm2.
A 1V MNC Bandgap Reference with High Temperature Stability.pdf
4.04 MB, 下载次数: 0
举报
站长推荐上一条 2/5 下一条
「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
查看 »
GMT+8, 2025-4-30 06:50 , Processed in 0.111579 second(s), 18 queries , MemCache On.
