查看: 571|回复: 0
[经验] a frequency compensation scheme for ldo voltage regulators
发表于 2022-8-6 12:39:36 | 显示全部楼层 |阅读模式
Abstract—A stable low dropout (LDO) voltage regulator topology for low equivalent series resistance (ESR) capacitive loads is presented. The proposed scheme generates a zero internally instead of relying on the zero generated by the load capacitor and its ESR combination for stability. It is demonstrated that this scheme realizes robust frequency compensation, facilitates the use of multilayer ceramic capacitors for the load of LDO regulators, and improves transient response and noise performance. Test results from a prototype fabricated in AMI 0.5- m CMOS technology provide the most important parameters of the regulator viz., ground current, load regulation, line regulation, output noise, and start-up time。
a frequency compensation scheme for ldo voltage regulators.pdf
562.22 KB, 下载次数: 0
GMT+8, 2024-11-28 14:38 , Processed in 0.111677 second(s), 16 queries , MemCache On.
