查看: 381|回复: 0
打印 上一主题 下一主题
[经验] DUTY CYCLE CORRECTOR WITH SAR FOR DDR DRAM APPLICATION
跳转到指定楼层
楼主
发表于 2022-8-4 11:07:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
ABSTRACT: Double Data Rate Dynamic Random Access Memory (DDR DRAM) has become important to develop a low-power high performance DCC(Duty Cycle Corrector) with better duty cycle accuracy. DDR DRAM increases the speed using Successive Approximation Register Duty Cycle Corrector (SAR DCC). The proposed DCC circuit will be implemented in a 0.18- um CMOS process. Here, Adjuster circuit delay line is being modified for low frequency. The main objective of this paper is to achieve fast duty correction . The state-of- the-art DDR DRAM is proposed where a mixed mode DCC. The circuit uses a digital feedback of SAR design process and performance analysis is presented in the paper. The proposed technique will reduce power consumption and speed gets improved in CMOS technology. The
entire work can be done by using CADENCE Virtuso.
DUTY CYCLE CORRECTOR WITH SAR FOR DDR DRAM APPLICATION.pdf
493.09 KB, 下载次数: 0
举报
站长推荐上一条 2/5 下一条
「工聚四方·创见未来」欧时RS入驻四方维创新中心线下沙龙
查看 »
GMT+8, 2025-4-30 08:18 , Processed in 0.109843 second(s), 18 queries , MemCache On.
