查看: 261|回复: 0
[经验] allen指导关于深亚微米低功耗ADC设计的博士论文
发表于 2022-8-4 11:01:19 | 显示全部楼层 |阅读模式
abstract:
High-speed, medium-resolution, analog-to-digital converters (ADCs) are important building blocks in a wide range of applications. High-speed, medium-resolution ADCs have been implemented by various ADC architectures such as a folding ADC, a subranging ADC, and a pipeline ADC. Among them, pipeline ADCs have proven to be efficient architectures for applications such as digital communication systems, data acquisition systems and video systems. Especially, power dissipation is a primary concern in applications requiring portability. Thus, the objective of this work is to design and build a low-voltage low-power medium-resolution (8-10bits) high-speed pipeline ADC in deep sub-micron CMOS technology.;The non-idealities of the circuit realization are carefully investigated in order to identify the circuit requirements for a low power circuit design of a pipeline ADC. The resolution per stage plays an important role in determining overall power dissipation of a pipeline ADC. The pros and cons of both large and small number of bits per-stage are examined. A power optimization algorithm is developed to decide more accurately which approach is better for lower power dissipation. Both identical and non-identical number of bit per-stage approaches are considered and their differences are analyzed.;A low-power, low-voltage 10-bit 100Msamples/s pipeline ADC was designed and implemented in a 0.18mum CMOS process. The power consumption was minimized with the right selection of the per-stage resolution based on the result of the power optimization algorithm and by the scaling down the sampling capacitor size in subsequent stages.
abbr_0ad22746c8a2073645169b15b98bbab7.pdf
1.5 MB, 下载次数: 0
GMT+8, 2025-2-16 20:22 , Processed in 0.105440 second(s), 16 queries , MemCache On.
