查看: 440|回复: 0
打印 上一主题 下一主题
[经验] An Embedded Test Circuit for RF Single Ended Low Noise Amplifiers
跳转到指定楼层
楼主
发表于 2022-8-3 08:23:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract—This paper presents a cost effective Embedded Test Circuit (ETC) for single ended Low Noise Amplifiers (LNAs).The ETC operation is based on the observation that the presence of catastrophic faults, like resistive bridgings, shorts and opens, or parametric faults, result in the attenuation of the output voltage amplitude (gain reduction). The ETC along with a single ended LNA have been designed in a 0.35μm CMOS technology to evaluate the efficiency of the proposed approach and experimental results are presented.
An Embedded Test Circuit for RF Single Ended Low Noise Amplifiers.pdf
375.16 KB, 下载次数: 0
举报
站长推荐上一条 2/4 下一条
【预约|参会享"豪"礼】2025慕尼黑上海设备展
查看 »
GMT+8, 2025-4-15 15:07 , Processed in 0.108351 second(s), 18 queries , MemCache On.
