查看: 401|回复: 0
[经验] RF PGA design 必看
发表于 2022-8-2 09:38:54 | 显示全部楼层 |阅读模式
Abstract − This paper presents a low-voltage high-frequency programmable gain amplifier (PGA) based on a very simple
gm-boosted source-degenerated differential pair using a combined polysilicon-MOS resistor network as the degeneration resistance. The PGA is designed in a standard 0.35 µm CMOS process and consumes less than 0.5 mW from a 1.8 V supply. The gain varies linearly in a dB-scale from 0 to 18 dB in 6 dB steps, while maintaining an almost constant bandwidth exceeding 170 MHz. With 0.2 Vp-p differential
output the total harmonic distortion levels are below -72 dB at 10 MHz over the whole gain setting range.
01522903_1.8VWideBandPGA.pdf
236.5 KB, 下载次数: 0
GMT+8, 2024-11-24 21:47 , Processed in 0.122138 second(s), 16 queries , MemCache On.
