查看: 358|回复: 0
打印 上一主题 下一主题
[经验] High power-supply rejection low drop-out regulator
跳转到指定楼层
楼主
发表于 2022-7-30 12:53:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Abstract—An off-chip load driving low drop-out regulator with high power-supply rejection is proposed in this paper. The 1.2-V
regulator uses adaptive frequency compensation and is stable at all load currents. A power-supply rejection of 70dB with load
and line regulation figures of under 2mV and 10mV for 1-350mA and 2.1-3.6V load current and power supply variations were measured on a 65-nm CMOS prototype consuming under 0.05mm2 core area and 40μA quiescent current.
High power-supply rejection low drop-out regulator.pdf
907.45 KB, 下载次数: 0
举报
站长推荐上一条 4/5 下一条
【预约参会三重礼】2025 瑞萨电子工业以太网技术日
查看 »
GMT+8, 2025-5-6 06:20 , Processed in 0.170225 second(s), 33 queries .
