查看: 248|回复: 0
[经验] Bandwidth Enhancement for Transimpedance Amplifiers
发表于 2022-7-30 11:48:36 | 显示全部楼层 |阅读模式
Abstract—A technique for bandwidth enhancement of a given amplifier is presented. Adding several interstage passive matching networks enables the control of transfer function and frequency response behavior. Parasitic capacitances of cascaded gain stages are isolated from each other and absorbed into passive networks. A simplified design procedure, using well-known low-pass filter component values, is introduced. To demonstrate the feasibility of the method, a CMOS transimpedance amplifier (TIA) is implemented in a 0.18- m BiCMOS technology. It achieves 3 dB bandwidth of 9.2 GHz in the presence of a 0.5-pF photodiode capacitance. This corresponds to a bandwidth enhancement ratio of 2.4 over the amplifier without the additional passive networks. The trans-resistance gain is 54 dB, while drawing 55 mA from a 2.5-V supply.The input sensitivity of the TIA is 18 dBm for a bit error rate of 10 12。
Bandwidth Enhancement for Transimpedance Amplifiers.pdf
978.83 KB, 下载次数: 0
GMT+8, 2024-11-28 16:27 , Processed in 0.119192 second(s), 16 queries , MemCache On.
