查看: 7024|回复: 4
BeagleBone Black Angstrom系统开机自启动
  • 签到天数: 1018 天
    发表于 2013-12-2 11:20:57 | 显示全部楼层 |阅读模式
    create myservice.service file in /lib/systemd/system/
    like this:
    1. [Unit]
    2. Description=CAN Bus bridge to Ethernet
    3. After=syslog.target network.target
    4. [Service]
    5. Restart=always
    6. ExecStart=/etc/init.d/startmyservice
    7. [Install]
    8. WantedBy=multi-user.target
    save it
    reload services:
    1. # systemctl --system daemon-reload
    see status:
    1. # systemctl status myservice.service
    start service:
    1. # systemctl start myservice.service
    stop service:
    1. # systemctl stop myservice.service
    restart service:
    1. # systemctl restart myservice.service
    at last, please enable your service to make it autostart
    1. # systemctl enable myservice.service
    you can use systemctl command to list and see all services status
    You can see something at here:
    http://beaglebone.cameon.net/home/autostarting-services
    http://www.nunoalves.com/open_source/?p=308
    英文实在不行了,上中文吧:
    整个思路是这样的,先编写service文件,编写完成之后用systemctl start命令去启动一下,并用systemctl status看一下是否启动成功了。然后可以再试试停止和重启,如果这些都对的话就可以用systemctl enable命令让它自启动。重启试试,重启之后可以用systemctl status看看是否启动来,也可以直接用systemctl命令看看所有的service状态。
    总之多使用systemctl status命令来调试你编写的service。
    转自CSDN:http://blog.csdn.net/trbbadboy/article/details/11141997
    发表于 2013-12-18 11:48:48 | 显示全部楼层
    感谢楼主分享,BBB的资料真心少……
    无聊
    2016-7-5 09:30
  • 签到天数: 7 天
    发表于 2014-11-14 16:16:59 | 显示全部楼层
    感谢楼主分享,
    慵懒
    2016-10-17 12:07
  • 签到天数: 306 天
    发表于 2014-11-28 09:41:27 | 显示全部楼层
    有点厉害。。。。。。。。。。。。。。。
    发表于 2017-12-27 11:04:00 | 显示全部楼层
    谢谢分享。
    GMT+8, 2024-11-20 04:36 , Processed in 0.144608 second(s), 25 queries , MemCache On.
