查看: 3260|回复: 1
FPGA设计的一本好书《Advanced FPGA Design》
发表于 2021-11-19 15:39:11 | 显示全部楼层 |阅读模式
FPGA设计的一本好书《Advanced FPGA Design - Architecture, Implementation, and Optimization》
有原理上的小结,也有实际的例子。
不知道以前是否有人发过,先共享出来了。
Contents
1. Architecting Speed 1
1.1 High Throughput 2
1.2 Low Latency 4
1.3 Timing 6
1.3.1 Add Register Layers 6
1.3.2 Parallel Structures 8
1.3.3 Flatten Logic Structures 10
1.3.4 Register Balancing 12
1.3.5 Reorder Paths 14
1.4 Summary of Key Points 16
2. Architecting Area 17
2.1 Rolling Up the Pipeline 18
2.2 Control-Based Logic Reuse 20
2.3 Resource Sharing 23
2.4 Impact of Reset on Area 25
2.4.1 Resources Without Reset 25
2.4.2 Resources Without Set 26
2.4.3 Resources Without Asynchronous Reset 27
2.4.4 Resetting RAM 29
2.4.5 Utilizing Set/Reset Flip-Flop Pins 31
2.5 Summary of Key Points 34
3. Architecting Power 37
3.1 Clock Control 38
3.1.1 Clock Skew 39
3.1.2 Managing Skew 40
3.2 Input Control 42
3.3 Reducing the Voltage Supply 44
3.4 Dual-Edge Triggered Flip-Flops 44
3.5 Modifying Terminations 45
3.6 Summary of Key Points 46
4. Example Design: The Advanced Encryption Standard 47
4.1 AES Architectures 47
4.1.1 One Stage for Sub-bytes 51
4.1.2 Zero Stages for Shift Rows 51
4.1.3 Two Pipeline Stages for Mix-Column 52
4.1.4 One Stage for Add Round Key 52
4.1.5 Compact Architecture 53
4.1.6 Partially Pipelined Architecture 57
4.1.7 Fully Pipelined Architecture 60
4.2 Performance Versus Area 66
4.3 Other Optimizations 67
5. High-Level Design 69
5.1 Abstract Design Techniques 69
5.2 Graphical State Machines 70
5.3 dsp Design 75
5.4 Software/Hardware Codesign 80
5.5 Summary of Key Points 81
6. Clock Domains 83
6.1 Crossing Clock Domains 84
6.1.1 Metastability 86
6.1.2 Solution 1: Phase Control 88
6.1.3 Solution 2: Double Flopping 89
6.1.4 Solution 3: fifo Structure 92
6.1.5 Partitioning Synchronizer Blocks 97
6.2 Gated Clocks in asic Prototypes 97
6.2.1 Clocks Module 98
6.2.2 Gating Removal 99
6.3 Summary of Key Points 100
7. Example Design: I2S Versus SPDIF 101
7.1 I2S 101
7.1.1 Protocol 102
7.1.2 Hardware Architecture 102
7.1.3 Analysis 105
7.2 SPDIF 107
7.2.1 Protocol 107
7.2.2 Hardware Architecture 108
7.2.3 Analysis 114
8. Implementing Math Functions 117
8.1 Hardware Division 117
8.1.1 Multiply and Shift 118
8.1.2 Iterative Division 119
8.1.3 The Goldschmidt Method 120
8.2 Taylor and Maclaurin Series Expansion 122
8.3 The CORDIC Algorithm 124
8.4 Summary of Key Points 126
9. Example Design: Floating-Point Unit 127
9.1 Floating-Point Formats 127
9.2 Pipelined Architecture 128
9.2.1 verilog Implementation 131
9.2.2 Resources and Performance 137
10. Reset Circuits 139
10.1 Asynchronous Versus Synchronous 140
10.1.1 Problems with Fully Asynchronous Resets 140
10.1.2 Fully Synchronized Resets 142
10.1.3 Asynchronous Assertion, Synchronous Deassertion 144
10.2 Mixing Reset Types 145
10.2.1 Nonresetable Flip-Flops 145
10.2.2 Internally Generated Resets 146
10.3 Multiple Clock Domains 148
10.4 Summary of Key Points 149
11. Advanced Simulation 151
11.1 Testbench Architecture 152
11.1.1 Testbench Components 152
11.1.2 Testbench Flow 153
11.1.2.1 Main Thread 153
11.1.2.2 Clocks and Resets 154
11.1.2.3 Test Cases 155
11.2 System Stimulus 157
11.2.1 MATLAB 157
11.2.2 Bus-Functional Models 158
11.3 Code Coverage 159
11.4 Gate-Level Simulations 159
11.5 Toggle Coverage 162
11.6 Run-Time Traps 165
11.6.1 Timescale 165
11.6.2 Glitch Rejection 165
11.6.3 Combinatorial Delay Modeling 166
11.7 Summary of Key Points 169
12. Coding for Synthesis 171
12.1 Decision Trees 172
12.1.1 Priority Versus Parallel 172
12.1.2 Full Conditions 176
12.1.3 Multiple Control Branches 179
12.2 Traps 180
12.2.1 Blocking Versus Nonblocking 180
12.2.2 For-Loops 183
12.2.3 Combinatorial Loops 185
12.2.4 Inferred Latches 187
12.3 Design Organization 188
12.3.1 Partitioning 188
12.3.1.1 Data Path Versus Control 188
12.3.1.2 Clock and Reset Structures 189
12.3.1.3 Multiple Instantiations 190
12.3.2 Parameterization 191
12.3.2.1 Definitions 191
12.3.2.2 Parameters 192
12.3.2.3 Parameters in Verilog-2001 194
12.4 Summary of Key Points 195
13. Example Design: The Secure Hash Algorithm 197
13.1 SHA-1 Architecture 197
13.2 Implementation Results 204
14. Synthesis Optimization 205
14.1 Speed Versus Area 206
14.2 Resource Sharing 208
eetop.cn_Advanced FPGA Design - Architecture, Implementation, and Optimization.part1.rar
4 MB, 下载次数: 18
eetop.cn_Advanced FPGA Design - Architecture, Implementation, and Optimization.part2.rar
1.41 MB, 下载次数: 14
    发表于 2021-12-25 17:11:13 | 显示全部楼层
    good material
    GMT+8, 2024-12-24 02:16 , Processed in 0.122335 second(s), 18 queries , MemCache On.
