查看: 451|回复: 0
经典的FIR设计软件附带Multirate filter 的C程序源代码
发表于 2021-11-19 15:22:47 | 显示全部楼层 |阅读模式
这个软件简单易用,直接解压即可使用.附带FIR,Multirate filter的C程序源代码,直接可用于dsp实现,或者FPGA设计参考.
    decim.c/.h          Decimating FIR: reduces the sampling rate by an integer
                        factor
    interp.c/.h         Interpolating FIR: increases the sampling rate by an
                        integer factor
    resamp.c/.h    Resampling FIR, to change sampling rate by an integral
                        ratio
    interp21.inc/.sfp   Coefficients and ScopeFIR project file for an
                        interpolate-by-21 FIR
    interp25.inc/.sfp Coefficients and ScopeFIR project file for an
                        interpolate-by-25 FIR
    mr_test.c           Multirate test program
    mr_test.sln/.vcproj Microsoft Visual C++ .net project files for the test
                        program
    makefile            GCC Make file for the test program
eetop.cn_ScopeFIR411.zip
878.84 KB, 下载次数: 2
GMT+8, 2024-12-25 21:21 , Processed in 0.125412 second(s), 16 queries , MemCache On.
