查看: 1810|回复: 0
Clifford E. Cummings经典论文合集
发表于 2021-11-18 10:30:32 | 显示全部楼层 |阅读模式
做代码设计的应该都知道这个人的,搜索了一下,没有搜到。
目录如下:
A Proposal To Remove Those Ugly Register Data Types From verilog.pdf
Asynchronous & Synchronous Reset Design Techniques.pdf
Coding And Scripting Techniques For FSM Designs With Synthesis-Optimized, Glitch-Free Outputs.pdf
Correct Methods For Adding Delays To Verilog Behavioral Models.pdf
fsm_perl, A Script to Generate RTL Code for State Machines and Synopsys Synthesis Scripts.pdf
full_case parallel_case, the Evil Twins of Verilog Synthesis.pdf
New Verilog-2001 Techniques for Creating Parameterized Models.pdf
Nonblocking Assignments in Verilog Synthesis, Coding Styles That Kill.pdf
Passive Device Verilog Models For Board And System-Level Digital Simulation.pdf
RTL Coding Styles That Yield Simulation and Synthesis Mismatches.pdf
Simulation and Synthesis Techniques for Asynchronous fifo Design with Asynchronous Pointer Comparisons.pdf
Simulation and Synthesis Techniques for Asynchronous FIFO Design.pdf
State Machine Coding Styles for Synthesis.pdf
Synchronous Resets, Asynchronous Resets,I am so confused,How will I ever know which to use.pdf
Synthesis and Scripting Techniques for Designing Multi-Asynchronous Clock Designs.pdf
The Fundamentals of Efficient Synthesizable Finite State Machine Design using NC-Verilog and BuildGates.pdf
THE IEEE VERILOG-2001 SIMULATION TOOL SCOREBOARD.pdf
VERILOG CODING STYLES FOR IMPROVED SIMULATION EFFICIENCY.pdf
Verilog Nonblocking Assignments With Delays,Myths & Mysteries.pdf
Verilog-2001 Behavioral and Synthesis Enhancements.pdf
eetop.cn_Clifford E. Cummings经典论文合集.rar
1.93 MB, 下载次数: 2
GMT+8, 2024-12-26 08:53 , Processed in 0.123269 second(s), 16 queries , MemCache On.
