查看: 1037|回复: 0
MIPI CSI2 Tx 和 Rx 的 IP核
发表于 2021-11-17 10:45:36 | 显示全部楼层 |阅读模式
目前,我们WWAGO公司的MIPI CSI2 的IP核,在业界处于领先位置。
我们的 CSI2 Tx (vs. other vendors)
We have a multiplexing CSI2 transmitter, which canmultiplex several data sources (e.g. 4 cameras) to a single CSI2 stream.Customers are forced to design a complex multiplexing means outside the IP core.
no other vendors have a multiplexing CSI2 transmitter.
我们的CSI2 Rx (vs. other vendors)
·   Our CSI2 Rx IP cores (inparticular the SVRPlus-CSI2) allow handling of several pixels per clock cycles;this enables the user to use slower clock frequencies
·    Our IP is the only oneto support 8-lane extended CSI2(目前全球,只有我们能提供支持8-lanes的CSI2 IP 核)
·   we are one of the only 2 IP cores with MIPI IOL certificate(全球通过 MIPI IOL认证的这个IP有2家,我们是其中一家)
GMT+8, 2024-12-26 20:12 , Processed in 0.111686 second(s), 15 queries , MemCache On.
