查看: 1689|回复: 0
[评测分享] [Wio Terminal开发板测评]+串行点阵模块驱动
  • 签到天数: 1742 天
    [LV.Master]伴坛终老
    发表于 2021-8-8 23:45:26 | 显示全部楼层 |阅读模式
    尽管Wio终端提供了强大的液晶屏显示功能,但这也不妨碍我们用它的扩展接口来进行驱动串行点阵模块的测试。
    串行点阵模块共有5个引脚,除2个电源引脚外,另3个引脚分别是片选引脚CS、数据引脚DIN及时钟引脚CLK。
    该模块与Wio终端的连接关系如下:
    CLK ---PIN_SPI_MOSI
    DIN ---PIN_SPI_MISO
    CS --- PIN_SPI_SCK
    故可将引脚定义为:
    #define CLK PIN_SPI_MOSI
    #define DIN PIN_SPI_MISO
    #define CS  PIN_SPI_SCK
    由于串行点阵模块所用的控制芯片为Max7219,故为其配置的初始化函数为:
    1. void Init_MAX7219(void)
    2. {
    3. Write_Max7219(0x0b, 0x07);
    4. Write_Max7219(0x0c, 0x01);
    5. Write_Max7219(0x0f, 0x00);
    6. }
    辅助串行发送数据的函数为:
    1. void Write_Max7219_byte(unsigned char DATA)
    2. {
    3. unsigned char i;
    4. digitalWrite(CS, LOW);
    5. for(i=8;i>=1;i--) {
    6. digitalWrite(CLK, LOW);
    7. if(DATA&0x80)  digitalWrite(DIN, HIGH);
    8. else  digitalWrite(DIN, LOW);
    9. DATA=DATA<<1;
    10. digitalWrite(CLK, HIGH);
    11. }
    12. }
    13. void Write_Max7219(char address,char dat)
    14. {
    15. digitalWrite(CS, LOW);
    16. Write_Max7219_byte(address);
    17. Write_Max7219_byte(dat);
    18. digitalWrite(CS, HIGH);
    19. }
    供显示所构建的字库其存储结果如下:
    unsigned chardisp[38][8]={
    {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C}, //0
    {0x10,0x30,0x50,0x10,0x10,0x10,0x10,0x10},//1
    {0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},   //2
    {0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},      //Y
    {0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},     //Z
    {0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},     //中
    {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE}, //国
    实现显示效果的程序其上传结果见图1所示,运行后的效果如图2所示。
    图1 程序上传
    图2 演示效果
    GMT+8, 2024-11-23 09:48 , Processed in 0.123682 second(s), 17 queries , MemCache On.
