查看: 2143|回复: 5
笔记,LCD
发表于 2013-11-8 21:29:47 | 显示全部楼层 |阅读模式
哈哈,以前都没发过贴,因为总是个菜鸟,怕被骂,但是总有一天要成长的,这几天抽了点空学了学板子上的液晶,今天燕子让活跃一下就支持下吧,首先提个建议,为什么板子上没有电源控制开关,下程序的时候老是插拔很不方便。
NHD-C12832A1Z-FSW-FBW-3V3FSTN液晶显示器和分辨率128 x 32像素,包含一个LCD控制器(ST7565R)和液晶面板(C12832_A1Z),白色背光。两种模式,并行和串行SPI,这里用的是SPI,优点是接口少,缺点人们只能写信号给显示器,因为阅读显示数据时仅支持使用并行接口。这里有个什么电源设置好像,没弄懂,3.3v6v 不知道怎么弄得,但是电路图上好像是3.3V,希望给弄明白哈,呵呵,然后背光的亮度是可调的通过定时器控制PWM来实现,英文不太好。
LCD的软件操作大同小异,但是也好久没有弄LCD了,没有用demo给的液晶写字符的程序,自己琢磨了一下,写了一个贴出来,帮忙看看,哈哈
#include <board.h>
#include <sysclk.h>
#include <st7565r.h>
unsigned char aa[28][8]={
                                                   {0x7E,0x10,0x10,0x7E,0x00,0x00,0x00,0x00},/*"H",0*/
                                                   /* (4 X 16, 黑¨²体¬? )*/
                                                   {0x30,0x68,0x58,0x00,0x00,0x00,0x00,0x00},/*"e",1*/
                                                   {0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00},/*"l",2*/
                                                   {0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00},/*"l",3*/
                                                   {0x30,0x48,0x48,0x30,0x00,0x00,0x00,0x00},/*"o",4*/
                                                   {0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00},/*",",5*/
                                                   {0x30,0x68,0x58,0x00,0x00,0x00,0x00,0x00},/*"e",6*/
                                                   {0x30,0x68,0x58,0x00,0x00,0x00,0x00,0x00},/*"e",7*/
                                                   {0x7E,0x48,0x58,0x20,0x00,0x00,0x00,0x00},/*"b",8*/
                                                   {0x30,0x48,0x48,0x30,0x00,0x00,0x00,0x00},/*"o",9*/
                                                   {0x20,0x68,0x78,0x00,0x00,0x00,0x00,0x00},/*"a",10*/
                                                   {0x00,0x30,0x08,0x00,0x00,0x00,0x00,0x00},/*"r",11*/
                                                   {0x30,0x48,0x7C,0x00,0x00,0x00,0x00,0x00},/*"d",12*/
                                                   {0x00,0x4E,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",13*/
                                                        /* (4 X 16 , 黑¨²体¬? )*/
                                                   {0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00},/*"I",14*/
                                                   {0x00,0x06,0x00,0x00,0x00,0x00,0x00,0x00},/*"'",15*/
                                                   {0x78,0x38,0x10,0x78,0x00,0x00,0x00,0x00},/*"m",16*/
                                                   {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},/*" ",17*/
                                                   {0x40,0x68,0x58,0x00,0x00,0x00,0x00,0x00},/*"z",18*/
                                                   {0x40,0x68,0x58,0x00,0x00,0x00,0x00,0x00},/*"z",19*/
                                                   {0x10,0x68,0x68,0x00,0x00,0x00,0x00,0x00},/*"s",20*/
                                                   {0x30,0x68,0x58,0x00,0x00,0x00,0x00,0x00},/*"e",21*/
                                                   {0x20,0x68,0x78,0x00,0x00,0x00,0x00,0x00},/*"a",22*/
                                                   {0x00,0x4E,0x00,0x00,0x00,0x00,0x00,0x00},/*"!",23*/
void lcd_init_display()
                    uint8_t page_address;
             uint8_t  column_address;
                   for (page_address = 0; page_address < 4; page_address++) {
                   st7565r_set_page_address(page_address);
                   for (column_address = 0; column_address < 128; column_address++) {
                            st7565r_set_column_address(column_address);
                            st7565r_write_data(0x00);
void lcd_display(char geshu,char hang,char lie)
                   uint8_t i=0;
             char j=0;
                   lie*=8;
                   j=geshu;
                   for (page_address = (hang-1); page_address < hang; page_address++) {
                   for (column_address = (lie-8); column_address < lie; column_address++) {
                            st7565r_write_data(aa[j]);
                            i++;
void lcd_display_str(char zishu)
                   char ii;
                   if(zishu>16)
                            for(ii=0;ii<16;ii++)
                                     lcd_display(ii,1,(ii+1));
                            for(ii=16;ii<zishu;ii++)
                                     lcd_display(ii,2,(ii-15));
                   else
                   for(ii=0;ii<zishu;ii++)
                   lcd_display(ii,1,ii);
int main(void)
         board_init();
         sysclk_init();
         st7565r_init();
         st7565r_set_page_address(0);
         st7565r_set_column_address(0);
    lcd_init_display();
         lcd_display_str(28);
   gpio_set_pin_high(NHD_C12832A1Z_BACKLIGHT);
   while(1)
  • 签到天数: 3747 天
    连续签到: 60 天
    [LV.Master]伴坛终老
    发表于 2013-11-9 08:09:18 | 显示全部楼层
    12864的多吧,这款还没有玩过
    无聊
    2014-5-8 11:45
  • 签到天数: 113 天
    [LV.6]常住居民II
    发表于 2013-11-9 08:49:19 | 显示全部楼层
    楼主给力
  • 签到天数: 364 天
    发表于 2013-11-9 10:32:00 | 显示全部楼层
    顶一个!!!!!!!!!!!
     楼主| 发表于 2013-11-9 13:10:52 | 显示全部楼层
    dwwzl 发表于 2013-11-9 08:09
    12864的多吧,这款还没有玩过
    12864,1206,1232的多,这款不常见
  • 签到天数: 361 天
    发表于 2013-11-11 14:53:48 | 显示全部楼层
    多多活跃  多多给力哈   同时咱也为了最后能得到板卡 努努力喽
    GMT+8, 2024-11-20 00:34 , Processed in 0.162497 second(s), 26 queries , MemCache On.
