查看: 3372|回复: 4
CC430中的Stack溢出问题
    郁闷
    2013-10-31 18:03
    发表于 2013-11-7 17:31:03 | 显示全部楼层 |阅读模式
    最近在开发利尔达CC430的套件,程序本来走的好好,自从我加入一个这样的程序
    #include "../inc/RF_Toggle_LED_Demo.h"
    #define  PACKET_LEN         (0x09)   // PACKET_LEN <= 61
    #define  RSSI_IDX           (PACKET_LEN+1)  // Index of appended RSSI
    #define  CRC_LQI_IDX        (PACKET_LEN+2)  // Index of appended LQI, checksum
    #define  CRC_OK              (BIT7)         // CRC_OK bit
    // 433MHz下的发射功率宏定义
    #define  PATABLE_VAL        (0x50)          // 0XC4-- 10 dBm;
                                                // 0X50-- 0  dBm;
                                                // 0X2D-- -6 dBm;
                                                // 0X26-- -12dBm;
                                                // 0x05-- -30dBm;
                                                // 0xc0-- max
    #define  LED_RBIT           6
    #define  LED_GBIT           7
    #define  LED_DIR            P2DIR
    #define  LED_OUT            P2OUT
    #define  LED_SEL            P2SEL
    #define  LEDR_ON()          LED_OUT|=(1<<LED_RBIT)
    #define  LEDG_ON()          LED_OUT|=(1<<LED_GBIT)
    #define  LEDR_OFF()         LED_OUT&=~(1<<LED_RBIT)
    #define  LEDG_OFF()         LED_OUT&=~(1<<LED_GBIT)
    #define  BUTTON_BIT         0
    #define  BUTTON_DIR         PJDIR
    #define  BUTTON_OUT         PJOUT
    #define  BUTTON_REN         PJREN
    #define  BUTTON_IN          PJIN
    int RSSI_dec1;
    extern RF_SETTINGS rfSettings;
    unsigned char packetReceived;
    unsigned char packetTransmit;
    unsigned char RxBuffer[64];
    unsigned char RxBufferLength = 0;
    const unsigned char TxBuffer[6]= {PACKET_LEN, 0x27, 0x23, 0x24, 0x25, 0x26};
    unsigned char buttonPressed = 0;
    unsigned int i,j,number,x,g;
    unsigned char flag;
    unsigned char second,min,hour,day,day_of_week,month,year;
    unsigned char aa[254];
    int RSSI_offset=74;
    unsigned int oldsavecount ;
    unsigned int savecount  ;
    unsigned int newcount ;
    unsigned int oldsavecarry;
    unsigned int savecarry;
    unsigned int newcarry;
    unsigned int carry;
      //__no_init
    unsigned char transmitting = 0;
    unsigned char receiving = 0;
    unsigned int  f,k;
    unsigned int time;
    unsigned int HOUR,MIN,SECOND;
    //unsigned char buffer0[2047];
    unsigned char sss[8]={0x01,0x02,0x03,0x04,0x05,0x06,0x07,0x08};
    unsigned char time1,time2;
    //初始化RTC
    void RTC_Init(void)
       RTCCTL01 |= RTCBCD + RTCHOLD + RTCMODE;
       // RTC enable, BCD mode, RTC hold    使能RTC,开启BCD模式,RTC保持
       // Disable RTC read ready interrupt    关闭RTC 中断
       // Disable RTC time event interrupt
       // 时间初始化
       RTCSEC =  0x40;                       // 设置秒
       RTCMIN =  0x36;                       // 设置分
       RTCHOUR = 0x01;                       // 设置小时
       // 日期初始化
       RTCDOW =  0x00;                       // 设置星期数 5
       RTCDAY =  0x20;                       // 设置日     04
       RTCMON =  0x10;                       // 设置月     01
       RTCYEAR = 0x2013;                     // 设置年   2013
       RTCCTL01 &= ~RTCHOLD;                 // Start RTC calendar mode
    * 函数名   :Read_Time
    * 功能     :RTC 实时时钟,时间读取
    * 输入参数 :无
    * 输出参数 :无
    * 作者     :
    void Read_Time()
       for(;RTCCTL01&RTCRDY;)         _NOP();
       for(;!(RTCCTL01&RTCRDY);)      _NOP();
       year= RTCYEAR ;         //读 年   寄存器
       month= RTCMON ;          //读 月   寄存器
       day= RTCDAY ;          //读 日   寄存器
       day_of_week = RTCDOW ;  //读 星期 寄存器
       hour = RTCHOUR ;         //读 时   寄存器
       min= RTCMIN ;          //读 分   寄存器
       second= RTCSEC;          //读 秒   寄存器
    * 函数名   :Write_RTC
    * 功能     :RTC 实时时钟,设置初始时间
    * 输入参数 :无
    * 输出参数 :无
    * 作者     :
    void Write_RTC()
        RTCCTL01 |= RTCHOLD ;
        RTCYEAR = year ;         //写 年   寄存器
        RTCMON = month ;         //写 月   寄存器
        RTCDAY = day ;           //写 日   寄存器
        RTCDOW = day_of_week ; //写 星期 寄存器
        RTCHOUR = hour  ;        //写 时   寄存器
        RTCMIN = min ;           //写 分   寄存器
        RTCSEC = second ;        //写 秒   寄存器
    void delayms(unsigned int n)
      unsigned int i,j;
      for(i=0;i<n;i++)
        for(j=0;j<800;j++);
    void InitRadio(void)
      // Set the High-Power Mode Request Enable bit so LPM3 can be entered
      // with active radio enabled
      PMMCTL0_H = 0xA5;
      PMMCTL0_L |= PMMHPMRE_L;
      PMMCTL0_H = 0x00;
      WriteRfSettings(&rfSettings);
      WriteSinglePATable(PATABLE_VAL);
    void Transmit(unsigned char *buffer, unsigned char length)
      RF1AIES |= BIT9;
      RF1AIFG &= ~BIT9;                         // Clear pending interrupts
      RF1AIE |= BIT9;                           // Enable TX end-of-packet interrupt
      WriteBurstReg(RF_TXFIFOWR, buffer, length);
      Strobe( RF_STX );                         // Strobe STX
    void ReceiveOn(void)
      RF1AIES |= BIT9;                          // Falling edge of RFIFG9
      RF1AIFG &= ~BIT9;                         // Clear a pending interrupt
      RF1AIE  |= BIT9;                          // Enable the interrupt
      // Radio is in IDLE following a TX, so strobe SRX to enter Receive Mode
      Strobe( RF_SRX );
    void ReceiveOff(void)
      RF1AIE &= ~BIT9;                          // Disable RX interrupts
      RF1AIFG &= ~BIT9;                         // Clear pending IFG
      // It is possible that ReceiveOff is called while radio is receiving a packet.
      // Therefore, it is necessary to flush the RX FIFO after issuing IDLE strobe
      // such that the RXFIFO is empty prior to receiving a packet.
      Strobe( RF_SIDLE );
      Strobe( RF_SFRX  );
    void FlashWrite(unsigned char *pc_byte,unsigned char *Datain,unsigned int count)
        //FCTL2 = FWKEY + FSSEL_1 + FN3 + FN4;//MCLK  16*FN4 + 8*FN3
        FCTL3 = FWKEY;
        FCTL1 = FWKEY + WRT;
        while(FCTL3 & BUSY);                //如果处于忙状态,则等待
        while(count--)
          *pc_byte++ = *Datain++;
       FCTL1 = FWKEY;
       FCTL3 = FWKEY + LOCK;
    void FlashRead(unsigned char *pc_byte,unsigned char *Dataout,unsigned int count)
      while(count--)
        *Dataout = *pc_byte;
        Dataout++;
        pc_byte++;
    void Time_conversion()
       Read_Time();
       HOUR=(((hour&0xf0)>>4)*10+(hour&0x0f));   //16进制bcd码转换为10进制。
       if(HOUR>12)
              HOUR=(HOUR-12);              //24小时制转换为12小时制。
       HOUR=((HOUR&0xf0)>>4)*10+(HOUR&0x0f);
       MIN=((min&0xf0)>>4)*10+(min&0x0f);
       SECOND=((second&0xf0)>>4)*10+(second&0x0f);
       time=( HOUR<<12)|( MIN<<6)|(SECOND);
       time1=(time>>8)&0x00ff;
       time2=time&0x00ff;
    void main( void )
      WDTCTL = WDTPW + WDTHOLD;
      SetVCore(2);
      ResetRadioCore();
      InitRadio();
      ReceiveOn();
      receiving = 1;
      RTC_Init();
      _EINT();
      while (1)
          ReceiveOn();
        receiving = 1;
         Time_conversion();
    #pragma vector=CC1101_VECTOR
    __interrupt void CC1101_ISR(void)
      switch(__even_in_range(RF1AIV,32))        // Prioritizing Radio Core Interrupt
        case  0: break;                         // No RF core interrupt pending
        case  2: break;                         // RFIFG0
        case  4: break;                         // RFIFG1
        case  6: break;                         // RFIFG2
        case  8: break;                         // RFIFG3
        case 10: break;                         // RFIFG4
        case 12: break;                         // RFIFG5
        case 14: break;                         // RFIFG6
        case 16: break;                         // RFIFG7
        case 18: break;                         // RFIFG8
        case 20:                                // RFIFG9
            RxBufferLength = ReadSingleReg( RXBYTES );
            ReadBurstReg(RF_RXFIFORD, RxBuffer, RxBufferLength);
               // Stop here to see contents of RxBuffer
            __no_operation();
           RSSI_dec1=CalculateRssi(RxBuffer[RSSI_IDX]);
          // f=(int)RxBuffer[5];
            // Check the CRC results
            if(RxBuffer[CRC_LQI_IDX] & CRC_OK)
              unsigned char *pc_byte;
              pc_byte= ( unsigned char *) 0x008910;
              LED_OUT |= (1<<LED_GBIT);         // Toggle LED1
              delayms(5);
           if(RxBuffer[0]==0x09&RxBuffer[1]==0x27)
                 flag=1;
                 newcount ++;
             FlashWrite((pc_byte+k),RxBuffer,8);
             k+=8;
           LED_OUT &=~(1<<LED_GBIT);
            break;
        case 22: break;                         // RFIFG10
        case 24: break;                         // RFIFG11
        case 26: break;                         // RFIFG12
        case 28: break;                         // RFIFG13
        case 30: break;                         // RFIFG14
        case 32: break;                         // RFIFG15
      __bic_SR_register_on_exit(LPM3_bits);
    这个函数是用来将采集到的RTC实时时钟的hour,min,second 3个BCD码组成的字节数据压缩成两个字节,现在我放在主函数里面使用,时间长了就会跑飞。进入一个这样的地方
    显示的Stack也是100%的状态,这是为什么呢?我将Options里面的Stack的数值加大到200,甚至是500都一样会溢出,这是什么情况呢?各位大神,求指教啊
    郁闷
    2013-10-31 18:03
     楼主| 发表于 2013-11-7 17:32:09 | 显示全部楼层
    加入的就是void Time_conversion()这个程序,上面漏说了。
  • 签到天数: 257 天
    发表于 2013-11-8 12:26:08 | 显示全部楼层
    是不是操作某些数据的时候越界操作了?不然一般不会乱飞的,除非遇到大的干扰的时候,430的抗干扰能力确实不敢恭维的
  • 签到天数: 257 天
    发表于 2013-11-8 12:28:22 | 显示全部楼层
    ??????你还有操作这个的?先取消操作测试下。
    郁闷
    2013-10-31 18:03
     楼主| 发表于 2013-11-8 17:53:07 | 显示全部楼层
    ??????你还有操作这个的?先取消操作测试下。 ...
    嗯,我取消了,后来我直接用利尔达的例程,都会stack溢出百分之百了。好奇怪啊,打电话给利尔达那边的人,他们说他们测试都没遇到这个情况
    GMT+8, 2025-1-11 21:32 , Processed in 0.154328 second(s), 24 queries , MemCache On.
