查看: 1240|回复: 0
[评测分享] 【百度大脑AI计算盒FZ5C】firmware power 驱动代码分析
  • 签到天数: 597 天
    发表于 2021-4-15 21:23:09 | 显示全部楼层 |阅读模式
    # 设备树
    1. zynqmp_power: zynqmp-power {
    2.     u-boot,dm-pre-reloc;
    3.     compatible = "xlnx,zynqmp-power";
    4.     interrupt-parent = <&gic>;
    5.     interrupts = <0 35 4>;
    6.     mboxes = <&ipi_mailbox_pmu1 0>,
    7.          <&ipi_mailbox_pmu1 1>;
    8.     mbox-names = "tx", "rx";
    9. };
    # match table
    1. static const struct of_device_id pm_of_match[] = {
    2.     { .compatible = "xlnx,zynqmp-power", },
    3.     { /* end of table */ },
    4. };
    5. MODULE_DEVICE_TABLE(of, pm_of_match);
    # driver
    1. static struct platform_driver zynqmp_pm_platform_driver = {
    2.     .probe = zynqmp_pm_probe,
    3.     .remove = zynqmp_pm_remove,
    4.     .driver = {
    5.         .name = "zynqmp_power",
    6.         .of_match_table = pm_of_match,
    7.     },
    8. };
    9. module_platform_driver(zynqmp_pm_platform_driver);
    # probe:调用了 eemi_ops 的两个方法,创建工作堆列,用到了 mailbox,收到 mailbox 消息添加工作队列,回复消息
    1. static int zynqmp_pm_probe(struct platform_device *pdev)
    2. {
    3.     int ret, irq;
    4.     u32 pm_api_version;
    5.     struct mbox_client *client;
    6.     eemi_ops = zynqmp_pm_get_eemi_ops();
    7.     if (IS_ERR(eemi_ops))
    8.         return PTR_ERR(eemi_ops);
    9.     if (!eemi_ops->get_api_version || !eemi_ops->init_finalize)
    10.         return -ENXIO;
    11.     eemi_ops->init_finalize();
    12.     eemi_ops->get_api_version(&pm_api_version);
    13.     /* Check PM API version number */
    14.     if (pm_api_version < ZYNQMP_PM_VERSION)
    15.         return -ENODEV;
    16.     if (of_find_property(pdev->dev.of_node, "mboxes", NULL)) {
    17.         zynqmp_pm_init_suspend_work =
    18.             devm_kzalloc(&pdev->dev,
    19.                      sizeof(struct zynqmp_pm_work_struct),
    20.                      GFP_KERNEL);
    21.         if (!zynqmp_pm_init_suspend_work)
    22.             return -ENOMEM;
    23.         INIT_WORK(&zynqmp_pm_init_suspend_work->callback_work,
    24.               zynqmp_pm_init_suspend_work_fn);
    25.         client = devm_kzalloc(&pdev->dev, sizeof(*client), GFP_KERNEL);
    26.         if (!client)
    27.             return -ENOMEM;
    28.         client->dev = &pdev->dev;
    29.         client->rx_callback = ipi_receive_callback;
    30.         rx_chan = mbox_request_channel_byname(client, "rx");
    31.         if (IS_ERR(rx_chan)) {
    32.             dev_err(&pdev->dev, "Failed to request rx channel\n");
    33.             return IS_ERR(rx_chan);
    34.         }
    35.     } else if (of_find_property(pdev->dev.of_node, "interrupts", NULL)) {
    36.         irq = platform_get_irq(pdev, 0);
    37.         if (irq <= 0)
    38.             return -ENXIO;
    39.         ret = devm_request_threaded_irq(&pdev->dev, irq, NULL,
    40.                         zynqmp_pm_isr,
    41.                         IRQF_NO_SUSPEND | IRQF_ONESHOT,
    42.                         dev_name(&pdev->dev),
    43.                         &pdev->dev);
    44.         if (ret) {
    45.             dev_err(&pdev->dev, "devm_request_threaded_irq '%d' "
    46.                         "failed with %d\n", irq, ret);
    47.             return ret;
    48.         }
    49.     } else {
    50.         dev_err(&pdev->dev, "Required property not found in DT node\n");
    51.         return -ENOENT;
    52.     }
    53.     ret = sysfs_create_file(&pdev->dev.kobj, &dev_attr_suspend_mode.attr);
    54.     if (ret) {
    55.         dev_err(&pdev->dev, "unable to create sysfs interface\n");
    56.         return ret;
    57.     }
    58.     return 0;
    59. }
    # 总结:仅初始化,确认版本,调用了 firmware 驱动
    # power 是自己实现的功能,通过 mailbox 传递消息,通过工作队列调整电源状态。更深层面是不是继续调用 firmware 方法,暂时未知
    GMT+8, 2025-1-12 04:04 , Processed in 0.125557 second(s), 16 queries , MemCache On.
