查看: 5888|回复: 10
Cookie NuMicro网上预订优惠页正式发布啦!
发表于 2012-9-27 18:31:13 | 显示全部楼层 |阅读模式
Cookie是一个开源的兼容Arduino的ARM原型平台。它基于32位的ARM Cortex M0/M0+/M3/M4系列单片机,将Arduino的概念扩到了基于ARM Cortex M的嵌入式开发中。Cookie平台包括大量可复用的硬件积木和软件积木,联合一套完整的CooCox开发工具,大大简化和加速了嵌入式开发速度。
Cookie NuMicro预订页链接:http://www.coocox.org/order.php
预订优惠活动截止日期为 2012.10.18号,届时可以参加新浪微博有奖转发活动,抓紧机会。
举报
  • 签到天数: 692 天
    发表于 2012-9-27 19:22:04 | 显示全部楼层
    活动不错!顶一下
    举报
    发表于 2012-9-27 23:07:43 | 显示全部楼层
    没有写明,具体是什么单片机
    举报
  • 签到天数: 518 天
    发表于 2012-9-28 10:03:54 | 显示全部楼层
    要是能再便宜点就好了,适合我等贫民
    举报
  • 签到天数: 692 天
    发表于 2012-9-28 19:12:01 | 显示全部楼层
    hhxb 发表于 2012-9-27 23:07
    没有写明,具体是什么单片机
    Numicro M051,新唐的M0系列,呵呵
    举报
  • 签到天数: 692 天
    发表于 2012-9-28 19:13:06 | 显示全部楼层
    The Cookie NuMicro edition is based on the Nuvoton Cortex M0 microcontrollerM0516LBN.
    Buy Cookie NuMicro Edition:
    Cookie NuMicro Edtion can be bought from both Element 14 and CooCox.
    Only 500 pcs are in production for the first batch, take pre-orders now!
    Features:
    ■Hardware CAD design files open under CC BY-SA 3.0 license in Eagle format.
    ■Working on both 3.3V and 5V.
    ■CoLinkEx (USB-JTAG/SW debug probe) onboard, Debug IN/OUT selectable with jumper.
    ■14 digital input/output pins (of which 6 can be used as PWM outputs), 6 analog inputs.
    ■1 power jack, 1 ICSP header, 1 standard DB9 connector for serial communication
    ■12MHz XTAL Frequency, SYSCLK operate up to 50MHz
    Main chip introduction:
    Nuvoton M0516LBN
    •32-bit with ARM Cortex-M0 core running at up to 50MHz.
    •64KB Flash for programming, 4KB SRAM, 4KB Flash for data memory, 4KB Flash for boot loader.
    •Built-in LDO for Wide Operating Voltage Range: 2.5V to 5.5V.
    •Up to 40 GPIO Pins with LQFP-48 package.
    •2 UARTs, 2 SPIs, 1 I2C, 4-channel 32-bit timer, 1 watchdog timer, up to 4 16-bit PWM generators with 8 PWM outputs, and 12bit SRC ADC up to 8 analog inputs.
    Download the sources:
    Hardware information:
    ■Circuit Schematic Diagram.pdf
    ■Components List.pdf
    ■Cookie.PCB(Designed with Eagle 6.11)
    ■Cookie's Gerber Files
    Software information:
    ■Userguide.pdf
    ■Cookie BSP
    How to use the board:
    The board have a build-in CoLinkEx, so you can use the CoLinkEx to download and debug. You will need to install the driver of CoLinkEx and CoIDE or CooCox Plugin.
    The signal of Cookie NuMicro Edition is compatible with Arduino UNO, see the detail in userguide.
    Related Reference:
    ■Install CoLinkEx Driver
    ■Using CoIDE to build and debug
    ■Using CoLinkEx in MDK
    ■Write Shields driver based on CoX
    http://www.coocox.org/Cookie/Cookie_Nuvoton.html
    举报
    发表于 2012-11-15 11:03:47 | 显示全部楼层
    楼主讲的很中肯啊,学习了,谢谢!
    举报
  • 签到天数: 1018 天
    发表于 2012-11-18 12:27:33 | 显示全部楼层
    我的板子啊~~~快快来吧!
    举报
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2012-11-24 13:05:59 | 显示全部楼层
    希望 价格 55元 不是那么贵
    举报
  • 签到天数: 29 天
    [LV.4]偶尔看看III
    发表于 2012-11-24 13:16:52 | 显示全部楼层
    希望 价格 55元 不是那么贵
    举报
    站长推荐上一条 1/2 下一条
    【预约|参会享"豪"礼】2025慕尼黑上海设备展
    查看 »
    GMT+8, 2025-3-4 11:06 , Processed in 0.180522 second(s), 33 queries , MemCache On.
