楼主: GY@艳
[线上活动] [第二轮]看NXP视频,玩盖楼,抢百元话费!
   关闭 [复制链接]
回帖奖励 8450 与非币 回复本帖可获得 10 与非币奖励! 每人限 1 次
抢楼 抢楼 本帖为抢楼帖,欢迎抢楼!
  • 签到天数: 772 天
    发表于 2013-11-4 18:09:32 | 显示全部楼层
    回帖奖励 +10 与非币
    也支持,顶顶起
    昨天 09:36
  • 签到天数: 3251 天
    连续签到: 18 天
    [LV.Master]伴坛终老
    发表于 2013-11-4 18:22:27 | 显示全部楼层
    主要特性和优势
    Full cycle AC conduction
    Triggering in three quadrants only
    Pin compatible with standard triacs
    Safe clamping of low energy over-voltage transients
    Protective self turn-on with high energy voltage transients
    Clamping structure ensures safe over-voltage withstand capability to IEC 61000-4-5
    Sensitive gate for easy logic level triggering
    Direct interfacing with low power drivers and microcontrollers
    Very high immunity to false turn-on by dV/dt
    Planar passivated for voltage ruggedness and reliability
    Superior reliability and product quality
    主要应用
    AC fan, pump and compressor controls
    Highly inductive, resistive and safety loads
    Large and small appliances (White Goods)
    Reversing induction motor controls
    Window blind controllers
    慵懒
    2021-9-26 15:11
  • 签到天数: 681 天
    发表于 2013-11-4 19:23:07 | 显示全部楼层
    NXP的芯片一向都挺好的,好活动
    5 小时前
  • 签到天数: 3897 天
    连续签到: 8 天
    [LV.Master]伴坛终老
    发表于 2013-11-4 19:37:18 | 显示全部楼层
    课程非常不错,可以学习,还有奖品,很好。
  • 签到天数: 773 天
    发表于 2013-11-4 19:58:40 | 显示全部楼层
    回帖奖励 +10 与非币
    抢个楼试试.
  • 签到天数: 641 天
    连续签到: 2 天
    发表于 2013-11-4 20:01:41 | 显示全部楼层
    回帖奖励 +10 与非币
    NXP的芯片一向都挺好的,好活动
    昨天 09:36
  • 签到天数: 3251 天
    连续签到: 18 天
    [LV.Master]伴坛终老
    发表于 2013-11-4 20:08:29 | 显示全部楼层
    AC Thyristor Triacs (ACTTs) are full cycle AC conduction power switches with gate triggering in three quadrants only and with self-protection against low and high energy over-voltage transients. Their specially designed structure ensures safe over-voltage withstand capability to IEC 61000-4-5. Protective self turn-on will follow high energy voltage transients, while lower energy transients will be clamped. A choice of gate sensitivities balances high false trigger immunity with ease of triggering. Their planar-passivated construction ensures voltage ruggedness and reliability.
    ACTTs are pin compatible with both 3Q Hi-Com and standard 4Q triacs.
    ACTT employs our fifth-generation, triple-implanted planar passivated technology. The extra performance and superior reliability of ACTT make it ideally suited to a wide range of applications that contain highly inductive, resistive and safety loads.
  • 签到天数: 1771 天
    [LV.Master]伴坛终老
    发表于 2013-11-4 21:11:29 | 显示全部楼层
    再来抢个楼
  • 签到天数: 2675 天
    [LV.Master]伴坛终老
    发表于 2013-11-4 21:39:36 | 显示全部楼层
    回帖奖励 +10 与非币
    已参加第一轮了, 这轮就不参加了
  • 签到天数: 117 天
    [LV.6]常住居民II
    发表于 2013-11-4 21:54:20 | 显示全部楼层
    回帖奖励 +10 与非币
    盖楼了哦哦
    GMT+8, 2024-11-23 07:15 , Processed in 0.215577 second(s), 32 queries , MemCache On.
