查看: 3037|回复: 5
Atmel XMEGA-A3BU试用报告二按键
  • 签到天数: 185 天
    [LV.7]常住居民III
    发表于 2013-10-25 12:45:34 | 显示全部楼层 |阅读模式
    Atmel XMEGA-A3BU试用报告二,IE11浏览器中图片怎么没法添加的啊,下面附件是3个独立键盘和触摸按键的原理图
    XMEGA-A3BU_XPLAINED_Design_Documentation_rev2.PDF
    4.07 MB, 下载次数: 4
  • 签到天数: 185 天
    [LV.7]常住居民III
     楼主| 发表于 2013-10-25 12:53:32 | 显示全部楼层
    关于3个独立按键,分别是PE的5口和PF的1口和2口,当按键按下去时,对应的引脚检测出低电平,检测语句为gpio_pin_is_low(io_id);
    按键对应的名字
    #define GPIO_PUSH_BUTTON_0              IOPORT_CREATE_PIN(PORTE, 5)#define GPIO_PUSH_BUTTON_1              IOPORT_CREATE_PIN(PORTF, 1)
    #define GPIO_PUSH_BUTTON_2              IOPORT_CREATE_PIN(PORTF, 2)
    所以检测语句如下面程序中所述
  • 签到天数: 185 天
    [LV.7]常住居民III
     楼主| 发表于 2013-10-25 12:56:23 | 显示全部楼层
    下面是程序是按键例程
    #include "xmega_a3bu_xplained.h"
    #include "touch_api.h"
    #include "keyboard.h"
    #include "cdc.h"
    * \brief Check the status of the keyboard
    * \param keybuffer  a keyboard_event struct to store keyboard status
    void keyboard_get_key_state(struct keyboard_event *keybuffer)
            // Variable to hold the key mask
            static uint8_t key_state;
            char key;
            if ((gpio_pin_is_low(GPIO_PUSH_BUTTON_0)) &&
                            !(key_state & KEYBOARD_ENTER_MASK)) {
                    // Key pressed
                    key_state |= KEYBOARD_ENTER_MASK;
                    keybuffer->keycode = KEYBOARD_ENTER;
                    keybuffer->type = KEYBOARD_PRESS;
            } else if ((gpio_pin_is_high(GPIO_PUSH_BUTTON_0))
                            && (key_state & KEYBOARD_ENTER_MASK)) {
                    // Key released
                    key_state &= ~KEYBOARD_ENTER_MASK;
                    keybuffer->type = KEYBOARD_RELEASE;
            } else if ((gpio_pin_is_low(GPIO_PUSH_BUTTON_1)) &&
                            !(key_state & KEYBOARD_UP_MASK)) {
                    // Key pressed
                    key_state |= KEYBOARD_UP_MASK;
                    keybuffer->keycode = KEYBOARD_UP;
            } else if ((gpio_pin_is_high(GPIO_PUSH_BUTTON_1))
                            && (key_state & KEYBOARD_UP_MASK)) {
                    // Key released
                    key_state &= ~KEYBOARD_UP_MASK;
            } else if ((gpio_pin_is_low(GPIO_PUSH_BUTTON_2)) &&
                            !(key_state & KEYBOARD_DOWN_MASK)) {
                    // Key pressed
                    key_state |= KEYBOARD_DOWN_MASK;
                    keybuffer->keycode = KEYBOARD_DOWN;
            } else if ((gpio_pin_is_high(GPIO_PUSH_BUTTON_2))
                            && (key_state & KEYBOARD_DOWN_MASK)) {
                    // Key released
                    key_state &= ~KEYBOARD_DOWN_MASK;
            // touch key
            } else if ((check_touch_key_pressed()) &&
                            !(key_state & KEYBOARD_BACK_MASK)) {
                    // Touch key pressed
                    key_state |= KEYBOARD_BACK_MASK;
                    keybuffer->keycode = KEYBOARD_BACK;
            } else if ((!check_touch_key_pressed()) &&
                    // Touch key released
                    key_state &= ~KEYBOARD_BACK_MASK;
            } else if ((key = cdc_getkey()) != KEYBOARD_NO_KEY) {
                    keybuffer->keycode = key;
            } else {
                    keybuffer->keycode = KEYBOARD_NO_KEY;
                    keybuffer->type = KEYBOARD_NO_EVENT;
  • 签到天数: 361 天
    发表于 2013-10-25 13:08:18 | 显示全部楼层
    帖子很赞哟!辛苦辛苦。。。
  • 签到天数: 295 天
    发表于 2013-10-26 08:19:39 | 显示全部楼层
    赞一个~~~~~~~~~~~~~··
  • 签到天数: 1244 天
    连续签到: 54 天
    发表于 2013-10-27 14:04:44 | 显示全部楼层
    辛苦辛苦。。。辛苦辛苦。。辛苦辛苦。。。。
    GMT+8, 2025-1-21 02:57 , Processed in 0.173364 second(s), 26 queries , MemCache On.
