FPGA控制TMS320C6678上电复位程序- module DSP_RST(
- input clk_25m,
- input RESETSTAT, //DSP复位状态 0表示复位态 1表示工作态
- input LOCKED, //时钟模块是否正常
- output ref LRESETNMIENz = 1'b0, //局部复位管脚
- output reg PORz=1'b0, //Power-on Reset
- output reg RESETFULL=1'b0, //Full Reset
- output reg RESET=1'b0
- reg [2:0] RES_STATE=2'b00;
- reg [15:0] por_counter=16'b0,resetfull_counter=16'b0,reset_counter=16'b0;
- parameter IDLE=2'b00,PULL_RESET=2'b01,PULL_POR=2'b10,PULL_RESETFULL=2'b11;
- always @(posedge clk_25m)
- if(LOCKED==1)
- begin
- case(RES_STATE)
- IDLE:
- RES_STATE<=PULL_RESET ;
- PULL_RESET: if(reset_counter<25000)
- begin
- reset_counter<=reset_counter+16'b1;
- RES_STATE<=RES_STATE;
- RESET<=1'b0;
- PORz<=1'b0;
- RESETFULL<=1'b0;
- end
- else
- begin
- RESET<=1'b1;
- LRESETNMIENz<=1`b1; //禁止局部复位。
- RES_STATE<=PULL_POR;
- end
- PULL_POR: if(por_counter<25000)
- begin
- por_counter<=por_counter+16'b1;
- PORz<=1'b0;
- end
- else
- begin
- PORz<=1'b1;
- RES_STATE<=PULL_RESETFULL;
- end
- PULL_RESETFULL:if(resetfull_counter<25000)
- begin
- resetfull_counter<=resetfull_counter+16'b1;
- RESETFULL<=1'b0;
- end
- else
- begin
- RESETFULL<=1'b1;
- end
- endcase
- end
- else
- begin
- reset_counter<=16'b0;
- resetfull_counter<=16'b0;
- por_counter<=16'b0;
- RES_STATE<=IDLE;
- RESET<=1'b0;
- PORz<=1'b0;
- RESETFULL<=1'b0;
- end
- endmodule
