package mytools;
import java.io.BufferedReader;
import java.io.BufferedWriter;
import java.io.FileReader;
import java.io.FileWriter;
import java.io.IOException;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
* 这是个配置文档操作类,用来读取和配置ini配置文档
* @author 由月
* @version 2004-08-18
* @修改 2008-05-22
public final class ConfigurationFile {
* 从ini配置文档中读取变量的值
* @param file 配置文档的路径
* @param section 要获取的变量所在段名称
* @param variable 要获取的变量名称
* @param defaultValue 变量名称不存在时的默认值
* @return 变量的值
* @throws IOException 抛出文档操作可能出现的io异常
public static String getProfileString(
String file,
String section,
String variable,
String defaultValue)
throws IOException {
String strLine, value = "";
BufferedReader bufferedReader = new BufferedReader(new FileReader(file));
boolean isInSection = false;
try {
while ((strLine = bufferedReader.readLine()) != null) {
strLine = strLine.trim();
//strLine = strLine.split("[;]")[0];
Pattern p;
Matcher m;
p = Pattern.compile("[url=file://[.*//]\\[.*\\]");
m = p.matcher((strLine));
if (m.matches()) {
p = Pattern.compile("[url=file://[(.*)//]\\[(.*)\\]");
m = p.matcher(strLine);
if (m.matches()) {
isInSection = true;
} else {
if (isInSection == true) {
String[] strArray = strLine.split("=");
if (strArray.length == 1) {
value = strArray[0].trim();
if (value.equalsIgnoreCase(variable)) {
value = "";
return value;
} else if (strArray.length == 2) {
value = strArray[1].trim();
return value;
} else if (strArray.length > 2) {
value = strLine.substring(strLine.indexOf("=") + 1).trim();
return value;
} finally {
bufferedReader.close();
return defaultValue;
* 修改ini配置文档中变量的值
* @param section 要修改的变量所在段名称
* @param variable 要修改的变量名称
* @param value 变量的新值
public static boolean setProfileString(
String file,
String section,
String variable,
String value)
String fileContent, allLine,strLine, newLine, remarkStr;
String getValue;
fileContent = "";
try {
while ((allLine = bufferedReader.readLine()) != null) {
allLine = allLine.trim();
System.out.println("allLine == "+allLine);
// if (allLine.split("[;]").length > 1)
// remarkStr = ";" + allLine.split(";")[1];
// else
// remarkStr = "";
// strLine = allLine.split(";")[0];
strLine = allLine;
Pattern p;
Matcher m;
if (m.matches()) {
if (m.matches()) {
isInSection = true;
} else {
getValue = strArray[0].trim();
if (getValue.equalsIgnoreCase(variable)) {
// newLine = getValue + " = " + value + " " + remarkStr;
newLine = getValue + " = " + value + " ";
fileContent += newLine + "\r\n";
fileContent += allLine + "\r\n";
BufferedWriter bufferedWriter =
new BufferedWriter(new FileWriter(file, false));
bufferedWriter.write(fileContent);
bufferedWriter.flush();
bufferedWriter.close();
return true;
}catch(IOException ex){
throw ex;
} finally {
return false;
* 程式测试
public static void main(String[] args) {
//String value = Config.getProfileString("sysconfig.ini", "Option", "OracleDB", "default");
//System.out.println(value);
try {
System.out.println("值已经改变!... "+ConfigurationFile.setProfileString("F:/update/gamewww.ini", "TestSect1", "1001", "111111"));
System.out.println("值读取成功!... "+ConfigurationFile.getProfileString("F:/update/gamewww.ini", "TestSect1", "1001", ""));
} catch (IOException e) {
System.out.println("错误 ......"+e.toString());
配置文件格式:
[TestSect1]
1001 = 111111
1002 = 222222
1003 = 333333
1004 = 444444
1005 = 555555
1006 = 666666 |
