查看: 2344|回复: 1
testinside的70-544题库优惠中
发表于 2010-11-10 13:45:26 | 显示全部楼层 |阅读模式
最新活动:
Testinside考题大师权威微软,思科,太阳,CIW中,IBM公司,北电网络,惠普,甲骨文等各大的IT认证题库,最新考题售价仅180元起。(时间有限!)
机会不容错过!需要的朋友一定要抓住这个机会!下面开始我们的正文!
70-544考试资料
TS: MS Virtual Earth 6.0, Application Development
科目编号:70-544
科目名称:TS: MS Virtual Earth 6.0, Application Development
语言:    英语,法语,德语,日语
考生:    开发人员
技术:    微软Visual Studio 2005
类型:    监考考试
相关:TS
Testinside题库价格:¥ 280.00
70-544 考试是Microsoft公司的 TS: MS Virtual Earth 6.0, Application Development 认证考试官方代号,TS: MS Virtual Earth 6.0, Application Development 认证作为全球IT领域专家 Microsoft 热门认证之一,是许多大中IT企业选择人才标准的必备条件
70-544考试概述:
About this Exam
When the exam begins, you can choose the programming language in which the code segments will appear. The available code languages for this exam are:
Microsoft Visual Basic 2005
Microsoft Visual C# 2005
Audience Profile
Candidates for this exam work on a team in a medium-sized or large development environment that uses Microsoft Visual Studio .NET 2003 Enterprise Developer or Visual Studio 2005. Candidates should have at least two years of experience developing distributed applications by using the Microsoft .NET Framework. Candidates should have a working knowledge of Visual Studio 2005.
An enterprise application developer can operate as a Microsoft Windows-based or Web-based client application developer and can develop middle-tier data and business logic components. Candidates should have at least three to five years of on-the-job experience dedicated to enterprise application development.
Candidates have worked in the following phases in the application life cycle:
Technical envisioning and planning
Design and development
Stabilizing and releasing
Credit Toward Certification
Exam 70-554: UPGRADE: MCSD Microsoft .NET Skills to MCPD Enterprise Application Developer by Using the Microsoft .NET Framework: Part 2: counts as credit toward the following certification(s):
Microsoft Certified Professional Developer: Enterprise Applications Developer
Microsoft Certified Technology Specialist: .NET Framework 2.0 Distributed Applications
70-544考试大纲:
Configuring and Customizing a Web Service Application
Configure SOAP messages.
Configure the formatting of SOAP messages for a Web service method.
Specify the basic information for a Web service application.
Specify the bindings of a Web service application by using the WebServiceBindingAttribute attribute.
Configure a Web service application by using a Machine.config file.
Configure a Web service application by using a Web.config file.
Creating, Configuring, and Deploying Remoting Applications
Create and configure a server application.
Create a server application domain.
Configure a server application programmatically.
Configure a server application by using configuration files.
Compile and build a server application.
Create a client application to access a remote object.
Create a remote object.
Configure a client application programmatically.
Configure a client application manually by using configuration files.
Access the remoting service by calling a remote method.
Call a remote method synchronously in a client application.
Create and serialize remotable types.
Create a remotable type.
Create generic types.
Configure a serialization formatter programmatically.
Configure a binary formatter.
Configure a SOAP formatter.
Implement Version Tolerant Serialization (VTS).
Implementing Web Services Enhancements (WSE) 3.0
Enable WSE in client and server applications.
Add references to WSE assemblies in client applications.
Edit the Web service proxy class to derive from the WebServicesClientProtocol class.
Add a element under the element in a configuration file.
Add a element to add the section to a configuration file.
Add a digital signature to a SOAP message and verify an existing SOAP message signature.
Sign a SOAP message digitally.
Verify a signed SOAP message.
Encrypt and decrypt a SOAP message.
Encrypt a SOAP message.
Decrypt an encrypted SOAP message.
Implement a policy for a Web service application.
Create a policy file manually.
Declare the set of policies in a policy file.
Map policies to SOAP endpoints.
Configure a policy file in a configuration file.
Create and enforce a custom policy.
Create a policy file by using the WseConfigEditor3 tool.
Set a policy in a client application and in a client computer.
Implement filters in a Web service application.
Add a filter.
Remove a filter.
Shuffle the order of the filters.
Enable the Trace filter.
Create custom input and output filters.
Implement WSE SOAP messaging.
Select a protocol.
Implement one-way SOAP messaging.
Implement bidirectional SOAP messaging.
Send the attachments from a Web service application.
Receive attachments in a client application.
Route SOAP messages by using a WSE router.
Create a WSE router application.
Configure a WSE router application.
Configure a referral cache for routing.
Add and verify security credentials.
Add security credentials to a SOAP message.
Verify security credentials.
Creating and Accessing a Serviced Component and Using Message Queuing
Create, configure, and access a serviced component.
Create a serviced component.
Add attributes to a serviced component.
Register a serviced component.
Implement security.
Add a reference to a serviced component in an application.
Create an instance of a serviced component.
Call the methods of a serviced component.
Create, delete, and set permissions on a message queue.
Create a message queue manually.
Create a message queue programmatically.
Delete a message queue.
Set permissions for a message queue programmatically.
Send messages to a message queue and delete messages from a message queue.
Create a message.
<span lang="EN-US" style="font-size: 10pt; color: black; font-family: Georgia"&gtost a message.
 楼主| 发表于 2010-11-10 13:46:30 | 显示全部楼层
RE:testinside的70-544题库优惠中
自己顶吧!
GMT+8, 2025-1-29 07:53 , Processed in 0.103912 second(s), 17 queries , MemCache On.
