查看: 2730|回复: 1
70-401考试资料分享
发表于 2010-11-6 15:01:05 | 显示全部楼层 |阅读模式
最新活动:
Testinside考题大师权威Microsoft、Cisco、SUN、CIW、IBM、Nortel、HP、Oracle等各大IT认证题库,最新考题售价仅180元起。(时间有限!)
机会不容错过!需要的朋友一定要抓住这个机会!下面开始我们的正文!
70-401 考试资料
TS: Microsoft System Center Configuration Manager 2007, Configuring
科目编号:70-401
科目名称:TS: Microsoft System Center Configuration Manager 2007, Configuring
语言(s):    英语,法语,德语,日语
观众(补):  IT专业人士
技术:    Microsoft System Center Configuration Manager 2007
类型:    监考考试
相关分类:MCTS
70-401 考试是Microsoft公司的 TS: Microsoft System Center Configuration Manager 2007, Configuring 认证考试官方代号,TS: Microsoft System Center Configuration Manager 2007, Configuring 认证作为全球IT领域专家 Microsoft 热门认证之一,是许多大中IT企业选择人才标准的必备条件。
下面是由Testinside考题大师带来的70-401 考试相关资料分享:
70-401 考试知识点:
Skills Being Measured
This exam measures your ability to accomplish the technical tasks listed below.
The percentages indicate the relative weight of each major topic area on the exam.
Deploying a System Center Configuration Manager 2007 (SCCM) Server (9 percent)
Set up and configure an Active Directory schema.
Migrate from an SMS 2003 hierarchy to SCCM 2007.
Configure an SCCM hierarchy.
Set up and configure security accounts.
Configuring an SCCM Infrastructure (19 percent)
Configure client agents.
Configure site boundaries.
Configure core site system roles.
Configure discovery methods.
Configure client installation.
Configure SCCM infrastructure for Internet-based client management.
Managing Resources (14 percent)
Build an SCCM collection by using queries.
Meter software usage.
Manage assets.
Manage inventory flow.
Manage client agents.
Distributing Applications (17 percent)
Manage packages.
Manage programs.
Manage advertisements.
Schedule distribution.
Track success and failure rates for distribution.
Manage distribution points.
Deploying Operating Systems (13 percent)
Capture a reference computer image.
Manage task sequences.
Configure site system roles related to deploying operating systems.
Deploy operating system packages.
Customize user state migration.
Deliver applications.
Securing a Network Infrastructure (13 percent)
Configure Network Access Protection (NAP).
Maintain NAP.
Migrate from Inventory Tool for Microsoft Update (ITMU) to Windows Software Update Services (WSUS).
Deploy software updates.
Manage vulnerability compliance.
Managing and Maintaining an SCCM Infrastructure (15 percent)
Manage system health.
Configure automatic maintenance tasks.
Create custom reports.
Maintain clients.
Manage systems by using configuration management.
Manage Wake on LAN.
70-401考试题库:
Exam : Microsoft 70-401
Title : Microsoft System Center Configuration Manager 2007,Configuring
1. You have a System Center Configuration Manager 2007 environment. You configure a software update deployment
package for a collection of server computers. The collection has a deployment schedule that coincides with the
nightly server maintenance window. You need to prevent users that are logged on to the servers from manually
installing updates in this deployment package only. What should you do?
A. On the Advertised Programs client agent, disable the Display a notification message setting.
B. On the Software Updates client agent, select the Enforce all mandatory deployments setting.
C. On the Software Updates client agent, select the Hide all deployments from end-users setting.
D. In the Deploy Software Updates Wizard, select the Suppress display notifications on client setting.
Answer: D
2. You have a System Center Configuration Manager 2007 environment. You install a new distribution point on a site
named S01. You need to ensure that the new distribution point on site S01 contains the same content as the
distribution point on a site named S02. Which wizard should you use?
A. the Distribute Software Wizard
B. the Deploy Software Updates Wizard
C. the Transfer Site Settings Wizard
D. the Copy Packages Wizard
Answer: D
3. You have a Systems Management Server (SMS) 2003 environment. The Microsoft SQL Server 2005 database for
your SMS 2003 server is replicated to a backup site. You are performing an in-place upgrade to System Center
Configuration Manager 2007. The SQL Server configuration causes the upgrade to fail. You need to complete an inplace
upgrade. What should you do?
A. Increase the replication interval of the SQL Server database.
B. Decrease the replication interval of the SQL Server database.
C. Detach the SMS database.
D. Disable SQL replication of the SQL Server database.
Answer: D
4. Your company has two System Center Configuration Manager 2007 sites that are installed at a main office and a
branch office. You export the task sequence for an operating system deployment from the main office. You import the
task sequence into the Configuration Manager site at the branch office. The task sequence deploys the operating
system, but an application installation fails. You need to deploy all applications in the task sequence. What should
you do?
A. Modify the extension of the task sequence file from .XML to .CFG before importing it into the branch office
Configuration Manager site.
B. Add a conditional statement to the task sequence to skip errors.
C. Use the Configuration Manager console to copy the application package to the branch office Configuration Manager
site.
D. Repackage each application with unique task sequence variables.
Answer: C
5. You have a System Center Configuration Manager 2007 environment. You create a package to deploy software
updates to a collection of client computers. You need to ensure that these updates are deployed to all client
computers as soon as possible. What should you do in the Deploy Software Updates Wizard?
A. Set the date and time when software will be made available to client computers to the current time. Select the Do
not set a deadline for software update installation option.
B. Select the As soon as possible schedule option.
C. Set a deadline for software update installation for the current date and time.
D. Set the date and time when software will be made available to client computers to the current time. Configure an
authorization time for the current date and time.
Answer: C
6. You have a System Center Configuration Manager 2007 environment. The primary site is configured to notify users
when applications are available. You have a new application package to deploy. You need to ensure that users do not
receive any messages from Configuration Manager during installation of the new application, and you need to ensure
that future application installations are not affected. What should you do in the program settings?
A. Clear the Allow users to interact with this program check box.
B. Select the Suppress program notifications check box.
C. Configure a run mode of Hidden.
D. Configure a run mode of Minimized.
Answer: B
7. You have a System Center Configuration Manager 2007 environment. Network Access Protection (NAP) is enforced
by using DHCP on a secured network. Your NAP policy requires all computers to have Microsoft Update enabled. Not
all users have local Administrator privileges. You notice that some users are not able to connect to the secured
network. You need to ensure that all users are able to access secured resources. What should you do?
A. Install a Windows Software Update Services (WSUS) server.
B. Configure automatic updates by using a Group Policy object (GPO).
C. Deploy updates by using login scripts.
D. Deploy updates by using startup scripts.
Answer: B
8. You have a System Center Configuration Manager 2007 environment running in mixed mode. You configure the site
server in the central site as a device management point. You create a mandatory assignment for a software package
for distribution to mobile devices. You discover that software distribution to mobile devices on the LAN is failing. You
need to configure Configuration Manager 2007 to support software deployment to mobile devices. Which two actions
should you perform? (Each correct answer presents part of the solution. Choose two.)
A. Enable Background Intelligent Transfer Service (BITS) and Web Distributed Authoring and Versioning (WebDAV)
extensions on the distribution point.
B. Disable Web Distributed Authoring and Versioning (WebDAV) extensions on the distribution point. Add an Internetbased
fully qualified domain name (FQDN) to the site system role.
C. Grant the Read permission for the package to the Authenticated Users security group.
D. Enable anonymous connections on the distribution point.
Answer: AD
9. You have a System Center Configuration Manager 2007 environment. You install a secondary site at a branch
office, and you configure the local IP subnet as the site boundary. The branch office site is connected to the primary
site by a 192-Kbps (kilobits per second) WAN link. You need to minimize bandwidth utilization for all client agent
policies from the branch office. What should you do?
A. Install a proxy management point at the secondary site.
B. Install a branch distribution point at the secondary site.
C. Configure all software package advertisements to Download content from distribution point and run locally.
D. Configure all software package advertisements to Run program from distribution point.
Answer: A
感谢Testinside考题大师的分享!
本文来自于:70-401考试资料分享(testinside 70-401 272.4元)
 楼主| 发表于 2010-11-6 15:01:35 | 显示全部楼层
RE:70-401考试资料分享
自己顶
GMT+8, 2025-2-19 06:06 , Processed in 0.120574 second(s), 17 queries , MemCache On.
