查看: 1815|回复: 0
NVIDIA英伟达上海急招ASIC Physical Design Engineer
发表于 2014-7-9 16:04:04 | 显示全部楼层 |阅读模式
亲们,
NVIDIA上海最近急招多位ASIC Physical Design Engineer, 需要3年及以上工作经验的。以下是职位描述,有兴趣的童鞋可以将简历发至:sasu@nvidia.com 或者加QQ详聊:524786472
GPU ASIC Physical Design engineer
As a senior member of our ASIC-PD team, you'll be working on streamlining thechip infrastructure process across product designs, focusing on full chiplayout planning (partitioning, planning clock distribution and other structure,methodology), partition/full chip timing closure (primetime scripts, othertools, etc) and gate-level design of high-speed logic
RESPONSIBILITIES:
· Chipintegration and netlist generation
· -Synthesis,Formal verification, netlist quality check
· Workin conjunction with Place and Route Engineers to achieve timing closure forboth partition level and full chip level
· Developand enhance entire timing flow from frontend (pre-layout) to backend(post-layout) at both chip and block level.
· Developcustom timing scripts using tcl/primetime for clock skew analysis, specialcircuits such as clock dividers, core logic  IO macros interfaces suchas PCI-E, Frame-Buffer/Memory, TMDS, etc.
· Developflow to physically partition and floorplan the entire chip.
· Develop scripts for performing ECO's.
MINIMUM REQUIREMENTS:
· BSor MS in Electrical Engineering or Computer Science
· Above3 years of relevant ASIC experience ideally with a focus in the chipintegration /synthesis/formal and timing closure
· -Excellent scripts skills
· -Excellent written and verbal communication skills in English
· -Ability to multiplex many issues, set priorities, and work in a teamenvironment
· -Keep up to date with leading edge technologies
GMT+8, 2024-12-26 08:56 , Processed in 0.118609 second(s), 15 queries , MemCache On.
