查看: 2385|回复: 0
Analog Mixed Signal Physical Design (Layout) Engineer
发表于 2011-4-12 19:40:13 | 显示全部楼层 |阅读模式
美资公司LSI上海研发中心高薪诚聘通讯存储领域人才,薪水待遇优厚,今年开始配股了,部分人员有出国培训机会。(部门内部推荐,成功机会更高)
有意者请将中英文简历发送至:asic_tapeout@hotmail.com
Job Description
LSI's Storage Peripherals Group is looking for an experienced IC physical design engineer to join the pre-amplifier design team. As a preamp physical design (layout) engineer you will work closely with circuit design to implement high-speed custom analog designs and develop mask layouts for customer products. You will join a cross-functional team responsible for developing leading edge high-speed magneto electronic read/write IC products that ultimately achieve high volume production
- Layout high speed analog and mixed-signal custom chips for the hard disk drive industry
- Work directly with a team of engineers to determine floor plan, routing and I/O requirements for preamp IC's
- Perform IC design rule and connectivity verification and drive products through mask release flows.
- Contribute to methodology improvements to increase layout and verification efficiency
Requirements/Qualifications (Education)
- Bachelor's degree in Electrical Engineering (or related field) or equivalent experience\Minimum three to five years experience in custom analog IC physical design
- Experience with schematic-driven layout, floor planning, chip level routing, design for manufacturing and design rule and connectivity verification is required
- Experience using Cadence Virtuoso XL and VCAR router preferred
- Familiarity with both analog and digital layout tools and flows, circuit design concepts and IC manufacturing processes desired
GMT+8, 2024-12-27 10:10 , Processed in 0.109354 second(s), 15 queries , MemCache On.
