查看: 2280|回复: 4
美资上海公司诚聘ASIC,Analog,Backend,System Application(内部推荐)
发表于 2008-9-4 17:20:05 | 显示全部楼层 |阅读模式
美资公司 LSI 上海研发中心诚聘ASIC,Analog,Backend Place&Route,System application工程师(内部推荐,成功机会更高)
薪水待遇优厚,部分人员有出国培训机会。
因公司发展需要,急聘网络通讯领域以下职位(部分职位要求有所更新,其中急招 System Application Engineer)。
有意者请将中英文简历发送至:asic_tapeout@hotmail.com
Requisition Number : 08-3604
Job Title : Analog IC Design Engineer
Country : China (CH)
State/Province/County : Shanghai
City : Shanghai
Requirements/Qualifications (Education) : Required Skills:
                        • Must be familiar with design concepts and architectures for complex analog signal processing functions including data conversion, switched-capacitor circuits, op-amps, pre-amps, comparators, filters, voltage and current references, phase-locked loops and their application to specific products.
                        • Experience in circuit design and layout of CMOS, BiCMOS or Bipolar silicon technologies as well as participation leading the development of IC projects is required.
                        • Experience with spice simulation and IC design CAD tools.
                        • Hard Disk Drive IC design experience is a plus.
                        Required Education:
                        • A minimum of a Masters degree in Electrical Engineering. PhD and/or 3 – 5 years of experience may qualify the candidate for consideration of a 8 or 10 grade level
                        Responsibilities:
                        Analog IC Design Engineers work closely with the design team and are responsible for developing design specifications, circuit topologies, performing circuit design, and proving out designs by simulation for storage IC’s from initial concept / specification through final verification of conformance to customer specifications. It also includes preparing block diagrams, schematics, simulation results and design analysis. Evaluate and help characterize prototype units. In addition support marketing in establishing custom IC requirements and providing estimation of new product development cycle time as well as participating in design review and technical discussion. Background should demonstrate good problem solving skills as well as strong intuitive ability and expert communication skills.
Job Description : Position Description:
                        A qualified applicant for this position would be responsible for transistor level design and development as well as the modification, validation and evaluation of block architecture and/or the entire IC for hard disk drive applications. The position includes working with a design team including other Analog Designers, System Architects, Test Engineers, and Product Engineers to define, architect, and design CMOS PHY/SerDes IC’s utilized in the mass storage industry.
 楼主| 发表于 2008-9-4 17:21:59 | 显示全部楼层
IC Design Engineer
Requisition Number : 08-3124
Job Title : IC Design Engineer
City : Shanghai
Requirements/Qualifications (Education) : Functional/Industry Knowledge:
                        Required:
                        - Minimum of 3-5 years Digital IC Design experience in a product development environment
                        - Proven Digital IC Design skills
                        - Must be familiar with synthesis, verification, static timing analysis, simulation, audits, timing
                        closure, floor-planning, customer interaction, CAD tools, and design support
                        - Must be willing to follow a structured design approach including design for reuse and provide
                        thorough design documentation
                        - Strong written and verbal communication skills
                        Desired:
                        - Past experience in a lead position giving guidance to other engineers
                        - Ethernet, USB experience, PCI-E, TCP/IP, ATM
                        Education/Certifications:
                        Required Degree: BS
                        Preferred Degree: MS
                        Preferred Major: Electrical Engineering or related discipline
Job Description : Job Responsibilities
                        Duties will include working within a Product Development Team to perform (design, layout, and evaluate)
                        architectural definition, digital logic design, and verification. Candidate will be involved in upfront product
                        planning activities including architectural tradeoffs, die size estimation, packaging selection, and technology
                        assessment. As a member of a design team, candidate will be responsible for managing the design from
                        concept to product launch.
 楼主| 发表于 2008-9-4 17:23:53 | 显示全部楼层
Verification Engineer
Requisition Number : 08-3115
Job Title : Verification Engineer
City : Shanghai
                        Required:
                        - Minimum of 3-5 years ASIC Verification experience in a product development environment
                        - Proven ASIC Design Verification skills
                        - Fluent in Verilog for design verification
                        - Experience with Specman or System Verilog
                        - Knowledge of data and telecommunication networking(TDM/IP/ATM/Ethernet)
                        - Experience with one or more scripting languages: awk, Perl, python
                        - Superior debugging skills for large ASIC designs
                        - Adaptable to evolving customer requirements
                        Desired:
                        - Experience with C/C++
                        Required Degree: BS
                        Duties will include working within a Product Development Team to develop reusable block-level and
                        ASIC testbenches using HVL. Develop new ASIC verification environments to support ASIC
                        development. Maintain existing ASIC verification environments. Review RTL architectural and
                        implementation specifications. Create stimulus drivers, monitors, dataflow models, and test plans to
                        verify function and performance of advanced multiprotocol networking ASICs. Define and develop
                        application tests required to verify ASICs meet functional and performance goals. Define and
                        implement functional coverage plans. Define and implement code coverage plans. Develop testing and
                        regression methodologies for new verification flow. Coordinate test plan implementation and
                        regressions with remote team. Incorporate reusability into all aspects of the verification environment.
                        Develop/maintain/enhance environment tools/scripts/makefiles.
 楼主| 发表于 2008-9-4 17:25:34 | 显示全部楼层
Backend Engineer Specialized in STA
Requisition Number : 08-3883
Job Title : Backend Engineer Specialized in STA
City : Shanghai
                        Required:
                        - Minimum of 3-5 years experience in Physical Design in a product development environment
                        - Proven physical design experience
                        - Expertise in circuit design, place and routing, signal integrity, power analysis, CTS design, DFT,
                        design rule and connectivity verification
                        - Strong timing analysis capabilities
                        - Good analytical and debugging skills
                        - Extremely disciplined in conducting checks and audits
                        - Must be technically adept, a strong team player, ability to manage multiple priorities
                        - Ability to interact intelligently and politely with customers
                        Desired:
                        - Familiarity with analog physical design, manufacturing and IC packaging
                        Education/Certifications :
                        Required Degree: BS
                        Duties will include working within a Product Development Team to work on leading edge ASIC
                        solutions in full custom and SoC environments. Design IC devices in conformance with both
                        LSI and customer requirements and sound design principles; Place and route(layout)
                        of integrated circuits to meet design requirements; Prepare project evaluations in conformance
                        with company policies/procedures; Provide CAD assistance to customer engineers and new staff
                        as required and/or requested; Keep up-to-date with all technical memos; Attend peer reviews
                        and provide feedback to ensure success of peer designs. Ideal candidate will have
                        experience/exposure to ASIC and full custom high-speed digital flows from design handoff
                        through manufacturing, and with strong timing analysis capabilities. Excellent communication
                        skills are needed, as the existing team spans multiple locations.
 楼主| 发表于 2008-9-4 17:27:23 | 显示全部楼层
System Applications Engineer
Requisition Number : 08-3591
Job Title : System Applications Engineer
City : Shanghai
                        Required:
                        - Minimum of 3 years software Engineering experience in a data networking or telecom product development. focused on processor microcode and API device driver with C/C++ on RTOS(Linux, VxWorks).
                        - Familiar with network architectures and applications, traffic management and resource management algorithms and functions
                        - Knowledge of wireline (ATM, TCP/IP, MPLS, PPP, Gigabit/Fast Ethernet, Frame Relay, SONET) and wireless (NodeB, RNC) networking protocols.
                        - Excellent problem solving and communication skills
                        - Experience with writing documents (data-sheet, application-notes, etc.)
                        Desired:
                        - software/hardware experience in LSI's Network Processor
                        - customer support experience
                        - experience in hardware development, knowledge of interface,e.g. PCI bus, UTOPIA, POSPHY, GE/FE.
                        Required Degree: BS
                        Preferred Degree:MS
                        Preferred Major: MSEE or MSCS
                        This is a Software Systems Applications Engineering position that involves the development and support of reference applications and API/FPI software for our customers. Software development includes creation of applications software for Network Processor configurations using runtime API software, development of fast path data processing and forwarding software. Software support includes providing technical help on integrating LSI supplied application software with customer systems, LSI supplied SDE (Software Development Environment), reviewing customer application code, creating debugger APIs, simulator maintenance, and contributing to system software API testing.
GMT+8, 2024-12-28 17:56 , Processed in 0.160063 second(s), 23 queries , MemCache On.
