查看: 2086|回复: 0
Tutorial of Ethernet Based UHF RFID Reader
发表于 2011-9-18 19:14:09 | 显示全部楼层 |阅读模式
  In this tutorial, we are going to build Ethernet based UHF RFID reader.
The hardware includes the following:
The following is a system picture:
The jump wire connection is as follows:
1. Spruce GPIO pin 40 -> UHF RFID GND
2. Spruce GPIO pin 14 -> UHF RFID RX
3. Spruce GPIO pin 15 -> UHF RFID TX.
The Ethernet firmware that is loaded to the spruce board can be downloaded here.
The TCP IP test tool can be downloaded here.
The following is a screen shot of using TCP to read the tag:
 By decoding the message, we can see that one tag is found,
GMT+8, 2024-11-22 15:04 , Processed in 0.116773 second(s), 15 queries , MemCache On.
