查看: 2324|回复: 0
提供CPU/H264_MPEG4/USB/PCIe/SATA/3D/2D/DDR2/24bit DSP/PHY等常用IP cores
发表于 2008-11-16 19:22:24 | 显示全部楼层 |阅读模式
1. Peripherals IP cores
  PCI express Solutions:
     - Endpoint controller/Rootmode/Switch Bridge Controller
     - PCIe1.0 PHY hard IP
  SATA Solutions:
     - SATA host controller
     - SATA device controller
     - SATA PHY hard IP
  USB2.0 Solutions:
     - USB2.0 OTG controller
     - USB2.0 host controller
     - USB2.0 device controller
     - USB2.0 PHY hard IP
     - USB2.0 OTG PHY hard IP
     - USB2.0 mobile PHY hard IP (small dieszie)
  USB1.0 Solutions:
     - USB1.0 host controller
     - USB1.0 device controller
     - USB1.0 HUB controller
     - USB1.0 FullSpeed/Low Speed PHY
  Wireless USB2.0 Solutions:
     - Wireless USB host controller
     - wireless USB device controller
     - wireless USB Host+device controller
  SDRAM memory controller Solutions
     -Support Mobile DDR-SDRAM (LPDDR)
     -Support Mobile SDR-SDRAM
     -Support DDR-SDRAM
     -Support SDR-SDRAM
     -Support Async-SRAM/Flash
  DDRn Memory controller Solutions
     -DDR2/DDR  SDRAM controller IP
     -DDR3/DDR2 SDRAM controller IP
     -DDR2/DDR  SDRAM PHY hard IP
     -DDR3/DDR2 SDRAM PHY hard IP
  Nand Flash Controller IP
  AMBA2.0/AMBA3.0 Peripherals IP cores (DMA/I2S/GPIO/SSI etc.)
  SDIO Device 2.0 Controller IP
  Mobile Storage host controller (Support SDIO/CEVA/MMC etc.)
  SD_MMC host controller IP
  Sony MemoryStick host controller IP
  Ethernet IP controller Solutions
     -10M/100M Ethernet MAC controller IP
     -10M/100M/1000M Ethernet MAC controller IP
     -10G Ethernet MAC controller IP
  Analog IO IP solutions:
     -DDR2 IO hard IP
     -DDR IO hard IP
     -Mobile DDR IO hard IP
     -LVDS IO hard IP
2. Multimedia IP cores
  GPU IP solutions
     -ATI 2D GPU IP
     -ATI 3D GPU IP
     -Img PowerVR MBX 3D GPU IP
     -Img PowerVR MBX-Lite 3D GPU IP
  Video IP Solutions
     -MPEG2 Decoder IP
     -MPEG4 Encoder IP
     -Video Decoder IP (Support H264/MEPG4 etc.)
     -Video Codec IP (Support H264/MPEG4 etc. Decoder/Encoder)
  Image Processing IP Solutions:
     -JPEG Encoder IP
     -JPEG Decoder IP
     -JPEG Codec IP
     -Motion JPEG Codec IP
3. CPU/MCU/DSP IP cores
  24bit CoolFlux DSP soft core
  8bit 8051 MCU IP
  PowerPC 460/440/405 soft CPU IP
  PowerPC PLB4 Peripherals
  ARC6xx/ARC7xx CPU IP
  MIPS4K CPU IP
  ARM9xx/ARM11xx CPU IP
  PrimeCell IP (Uart/GPIO/SSI/DC-DC converter/Audio Codec Interface etc.)
4. EDA Tools Platform
  4.1 Synopsys platforms
      -Synthesis Solutions (Logic/Physical SYntehsis)
      -Power Solutions (PowerCompiler/PrimePower/PowerRail etc)
      -DFT Solutions (DFT Compiler/TestCompiler/ATPG etc.)
      -Physical Design Solutions (Layout/DRC&LVS/Extractor tools)
      -Mixed Signal design Solutions (Hsim/Hspice/Nanosim)
      -Digital Simulation (VCS/VERA/VCS-MX)
  4.2 Mentor platforms
      -Calibre/xCalibre design platforms
      -DFT/ATPG/BIST Design platforms
      -Modelsim platforms
  4.3 atrenta Design platforms
      -spyglass
      -spyglass-cdc
      -spyglass-dft
      -spyglass-power
      -spyglass-constraints
需要的可以email联系:jasper1949@gmail.com microcore@sina.com
GMT+8, 2024-11-1 10:38 , Processed in 0.107377 second(s), 15 queries , MemCache On.
