查看: 987|回复: 0
独家提供一体式POGOPIN探针
发表于 2014-5-29 14:13:13 | 显示全部楼层 |阅读模式
 Utilizing the best attributes of each material and eliminating many individual shortcomings, instead of handmade, OBP Pin is produced 100% by fully automated machinery.OBP pin is a very attractive, cost effective alternative for test solution.
 若有兴趣可致电18915583595(carl)或邮件carl@c2wide.com.
Model No#
6538
3846A/B
3052
Type of Test
IC Test
Burn-In
IC Test
Ball Pitch
0.8/1.0mm
0.5mm
0.4mm
Pin diameter/Length(mm)
0.65/3.8
0.38/4.6
0.30/5.1
Spring Force(+/-20%)
25g@0.6mm,
25g@0.4mm   Recommended Stroke
23g@0.5mm
35g@0.8mm
Operating Temperature
-55~130
-55~130
-55~130
Current Capacity
3.0A continuous
3.0A continuous
3.0A continuous
Resistance
under 50mΩ
under 100mΩ
under 50mΩ
Band Width (S21)
-0.63dB@20GHz
-1.0dB@12GHz
 S21
http:///file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image001.jpg
http:///file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image003.jpg
 S11
http:///file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image004.jpg
http:///file:///C:/DOCUME~1/ADMINI~1/LOCALS~1/Temp/msohtmlclip1/01/clip_image006.jpg
GMT+8, 2024-12-20 00:55 , Processed in 0.114778 second(s), 15 queries , MemCache On.
