查看: 825|回复: 0
提供E48SH1R540PRFA芯片解密技术支持
发表于 2012-10-18 15:55:50 | 显示全部楼层 |阅读模式
   深圳市有限公司会根据不同客户的不同需求给出不同的、合理的、科学的解密方案与解密服务,从而提供专业供芯片解密、IC解密、单片机解密等解密服务。以下是E48SH1R540PRFA芯片解密特性的相关描述,仅供参考。
  FEATURES
  ·  High efficiency: 89% @1.5V/40A
  ·  Size: 58.4mm x 22.8mm x 9.5mm(2.30”x0.90”x0.37”)
  ·  Industry standard pin out
  ·  Fixed frequency operation
  ·  Input UVLO, Output OTP, OCP, OVP
  ·  Monotonic startup into normal and pre-biased loads
  ·  Secondary control, very fast transient response
  ·  2250V Isolation and basic insulation
  ·  No minimum load required
  ·  SMD and through-hole versions
  ·  No negative current during power or enable on/off
  ·  ISO 9001, TL 9000, ISO 14001, QS 9000, OHSAS 18001 certified manufacturing facility
  ·  UL/cUL 60950 (US & Canada) recognized,and TUV (EN60950) certified
  ·  CE mark meets 73/23/EEC and 93/68/EEC directive
  更多相关芯片解密、IC解密、单片机破解等详细信息请访问咨询http://www.atmeldaili.com
GMT+8, 2024-11-17 14:30 , Processed in 0.114390 second(s), 15 queries , MemCache On.
