查看: 876|回复: 0
MSP430F1111芯片解密技术支持
发表于 2012-10-15 16:02:06 | 显示全部楼层 |阅读模式
   MSP430F1111解密等TI系列MSP430单片机是TI芯片解密网的优势解密项目之一,针对该系列众多典型IC芯片型号,我们均能提供安全可靠、价格合理的解密方案。在芯片解密技术实现过程中,解密工程师一般需要对芯片的内部结构及加密特征进行详细分析,从而根据芯片本身的加解密性质选择最合适、最安全可靠的解密方案,最大限度保证解密的成功率。
  MSP430F1111 FEATURES:
  Low Supply Voltage Range 1.8 V to 3.6 V
  Ultralow-Power Consumption
  Active Mode: 160 μA at 1 MHz, 2.2 V
  Standby Mode: 0.7 μA
  Off Mode (RAM Retention): 0.1 μA
  Wake-Up From Standby Mode in less than 6 μs
  16-Bit RISC Architecture, 125 ns
  Instruction Cycle Time
  Basic Clock Module Configurations:
  Various Internal Resistors
  Single External Resistor
  32-kHz Crystal
  High-Frequency Crystal
  Resonator
  External Clock Source
  16-Bit Timer_A With Three
  Capture/Compare Registers
  On-Chip Comparator for Analog Signal
  Compare Function or Slope A/D
  Conversion
  Serial Onboard Programming,No External Programming Voltage Needed
  Programmable Code Protection by Security Fuse
本资料由www.tms320jiemi.org整理提供。
GMT+8, 2024-12-21 02:48 , Processed in 0.115815 second(s), 15 queries , MemCache On.
