查看: 888|回复: 0
R&S TV GENERATOR PAL SGPF电视视频信号发生器
发表于 2011-7-17 17:33:45 | 显示全部楼层 |阅读模式
销售/专业维修/回收R&S  TV GENERATOR PAL SGPF电视视频信号发生器电:13554811696
SGPF digitally generates a PAL composite colour video signal (CCVS) coded over the eight-field sequence with a resolution of 12 bits. Two LSI gate arrays convert the Y, CB and CR components into the digital CCVS which features an accurately defined colour-subcarrier/sync-pulse (SC/H) phase. For identification of the beginning of the eight-field sequence, the PAL identification pulse can be inserted into line 7 of the first field.
With the genlock option fitted, SGPF offers the possibility of inserting test signals into a program signal. If no program signal is available, the selected video test pattern is through-connected to the program output.
The test signals numbering more than 30 comprise the following groups:
Test pattern to German FuBK standard or general-purpose test pattern with optional source identification, crosshatch pattern and VTR signal
CCIR insertion test signals
Squarewave signals (50 Hz, 15 kHz, 250 kHz)
Sawtooth signals
Multipulse, H sweep, sin x/x and coring signals
Black burst, vertical staircase, white field and bounce signals
GMT+8, 2024-12-22 15:34 , Processed in 0.109227 second(s), 15 queries , MemCache On.
