查看: 694|回复: 0
TDS540D 数字示波器
发表于 2011-7-17 17:28:27 | 显示全部楼层 |阅读模式
销售/专业维修/回收TDS540D 数字示波器电:13554811696
品牌:美国泰克  Tektronix
Product Description:
Tektronix TDS540D Oscilloscope, Digital: 500MHz,2GSa/s,4ch (Stand alone)
The Tektronix TDS540D oscilloscope is a graph-displaying device – it draws a graph of an electrical signal. In most applications, the graph shows how signals change over time: the vertical (Y) axis represents voltage and the horizontal (X) axis represents time. The intensity or brightness of the display is sometimes called the Z axis.
The Tektronix TDS540D oscilloscope's simple graph can tell you many things about a signal, such as: the time and voltage values of a signal, the frequency of an oscillating signal, the “moving parts” of a circuit represented by the signal, the frequency with which a particular portion of the signal is occurring relative to, other portions, whether or not a malfunctioning component is distorting the signal, how much of a signal is direct current (DC) or alternating current (AC) and how much of the signal is noise and whether the noise is changing with time.
Performance Characteristics of the TDS540D
Form FactorBenchtop
Bandwidth500 MHz
Number of Channels4 ch
Simultaneous Channels4 ch
Simultaneous Maximum Sampling Rate/ch2 GSa/s
One ch. only max. sampling rate2 GSa/s
Max. Single Shot bandwidth500 MHz
Max. Record Length50000 pt/sec
Min. Vertical Sensitivity1 mV/div
Maximum Vertical Sensitivity10 V/div
Rise time700 ps
Number of Bits8 bits
Input Impedance1 MOhm
Input Impedance (alternate)50 Ohm
Input CouplingAC,DC,GND
Maximum Input Voltage400 Vrms
Main time base - lowest500 ps/div
Main time base - highest10 s/div
Timebase accuracy0.0025 %
Trigger SourceExternal,Internal
Trigger ModesAuto,Edge,Logic,Normal,Pulse,Single
Minimum Trigger Holdoff16 ns
Minimum Glitch Trigger1 ns
Display TypeLCD
Display Size17.78 cm
Display modesDot,Persistence,Vector
GMT+8, 2024-12-22 14:58 , Processed in 0.119742 second(s), 15 queries , MemCache On.
