查看: 958|回复: 0
!求购HP8722A网络分析仪HP8722A 李R
发表于 2011-5-5 22:23:02 | 显示全部楼层 |阅读模式
联系人:李先生
手机: 13377777186
QQ:64266383  电话:0769-27261601
邮箱:tosstar5512@163.com
网址: www.ershou17.com
地址:东莞市塘厦镇塘富路迎宾大道
Agilent 8722A|HP8722A|HP-8722A 40G射频网络分析仪 50MHz-40GHz
Specifications
* Frequency Accuracy: +/- 10ppm
* Frequency Range: 50MHz - 40GHz
* Frequency Resolution: 1Hz
* Output Power Range: -75dBm - -5dBm
* Output Resolution: 15dB
* Sweep Range: 0.01dB
Key Points
* 50MHz to 13.5, 20, or 40GHz frequency coverage
* New processor makes measurements and data transfers up to seven times faster
* Fast-sweeping, built-in synthesized source
* Integrated solid-state switching S-parameter test set
* Vecter receiver, error correcton, time domain
* Up to 105dB dynamic range
GMT+8, 2024-12-22 09:53 , Processed in 0.108454 second(s), 15 queries , MemCache On.
