查看: 5616|回复: 4
有关BBB的问题,进来看下 !!
    无聊
    2014-5-18 22:32
  • 签到天数: 257 天
    发表于 2013-10-4 22:13:57 | 显示全部楼层 |阅读模式
    BBB可以用SD卡升级eMMC上的系统然后从eMMC引导进入系统(升级eMMC需40-50分钟);也可以从SD卡直接boot进入系统(<1分钟)。我有几个问题:
    1.如果每次从SD卡boot,那2G的eMMC不就浪费了?有别的用途吗?
    2.你看这个网页:file:///C:\Users\Qinkai\AppData\Local\Temp\%W@GJ$ACOF(TYDYECOKVDYB.pnghttp://circuitco.com/support/index.php?title=Ubuntu_On_BeagleBone_Black
    这里面从SD卡直接boot的时候,也需要按住uSD BOOT。是不是说uSD BOOT键有两个功能,用来烧写eMMC和用来从SD卡boot?把MLO文件删了之后,它的第二个功能就没有了,直接可以上电即从SD卡boot了?
    3.我实验室的显示器都没有hdmi,但是我自己的笔记本电脑有,我可以把bbb的hdmi连到笔记本的hdmi上用吗?
    慵懒
    2016-6-15 14:29
  • 签到天数: 6 天
    发表于 2013-10-5 12:25:02 | 显示全部楼层
    笔记本上的hdmi貌似是输出用,不知道输入可不可以,其实楼主可以弄个远程桌面就行了
  • 签到天数: 87 天
    [LV.6]常住居民II
    发表于 2013-10-6 13:25:35 | 显示全部楼层
    貌似:
    1.从SD卡直接boot进入系统,可以通过SD卡里的系统访问eMMC,这样可以当做存储设备嘛
    2.关于BOOT switch,可以看BBB_SRM.pdf,
    5.3.5  Boot Modes
    As mentioned earlier, there are four boot modes:
      eMMC Boot…This is the default boot mode and will allow for the fastest boot
    time and will enable the board to boot out of the box   using the pre-flashed OS
    image without having to purchase an SD card or an SD card writer.
      SD  Boot…This  mode  will  boot  from  the  uSD  slot.  This  mode  can  be  used  to
    override  what  is  on  the  eMMC  device  and  can  be  used  to  program  the  eMMC
    when used in the manufacturing process or for field updates.
      Serial  Boot…This  mode  will  use  the  serial  port  to  allow  downloading  of  the
    software direct. A separate USB to serial cable is required to use this port.
      USB Boot…This mode supports booting over the USB port.
    Software to support USB and serial boot modes is not provided by beagleboard.org.
    Please contact TI for support of this feature.
    A switch is provided to allow switching between the modes.
      Holding the  boot  switch down during  a removal and reapplication of power
    without a SD card inserted will force the boot source to be the USB port and if
    nothing  is  detected  on  the  USB  client  port,  it  will  go  to  the  serial  port  for
    download.
      Without holding the switch, the board will boot  try to boot from the    eMMC.
    If it is empty, then it will try booting from the uSD slot, followed by the serial
    port, and then the USB port.
      If  you  hold  the  boot  switch  down  during  the  removal  and  reapplication  of
    power to the board, and you have a uSD card inserted with a bootable image,
    the board will boot from the uSD card.
    NOTE: Pressing the RESET button on the board will NOT result in a change of the
    boot mode. You MUST remove power and reapply power to change the boot mode.
    The boot pins are sampled during power on reset from the PMIC to the processor.
    The reset button on the board is a warm reset only and will not force a boot mode
    change.
    不按BOOT switch,删了 eMMC的MLO,板子就不能从那里启动,于是按顺序转向uSD slot
    当SD卡插着的时候,按下BOOT switch的功能应该就1个吧,就是从uSD slot启动,而不是 eMMC。你说的“用来烧写eMMC和用来从SD卡boot”,不都一样嘛,就是从uSD slot启动,只不过烧写的时候运行的不是系统,而是往eMMC安装系统。
    3.完全不知道
  • 签到天数: 886 天
    发表于 2013-12-15 17:04:13 | 显示全部楼层
    笔记本上的HDMI是只有输出功能的,用笔记本作为显示器比较简单的做法是VSN。但是BBB的HDMI是向下兼容DVI接口的,用比一个一两块钱的转接头就能实现在DVI接口的显示器上使用BBB。
  • 签到天数: 772 天
    发表于 2014-1-14 16:18:35 | 显示全部楼层
    为什么总先升级呢,就用板上的emm不行么
    GMT+8, 2024-12-21 15:41 , Processed in 0.144226 second(s), 22 queries , MemCache On.
