查看: 1445|回复: 0
BGA测试插座,BGA Socket
发表于 2010-3-29 14:49:19 | 显示全部楼层 |阅读模式
www.lingmei.com.cn
产品特点:
  •     Any package style: ceramic & plastic BGA, CSP, LGA, CGA, PSGA, MLF/QFN,QFP, SOIC, and other standard packages, custom packages or bare die
  •     Inductance: less than 2nH
  •     -1dB bandwidth: >14GHz for compression style; 3GHz for SMD style
  •     available for any chip size and grid pattern
  •     Same PCB layout as the IC (no holes required for SMD socket)
  •     Minimal keepout area of 6mm beyond the IC’s periphery
  •     Raised SMD style for lifting socket over adjacent components
  •     Low profile socket (standard Twist Lock is less than 10mm high with IC)
  •     Contact force: max 40 grams per contact; lower forces available
  •     Semi-custom design = lower cost and tailored to your needs
举报
站长推荐上一条 3/3 下一条
【预约参会三重礼】2025 瑞萨电子工业以太网技术日
查看 »
GMT+8, 2025-3-8 01:15 , Processed in 0.112728 second(s), 15 queries , MemCache On.
