查看: 1121|回复: 0
信号发生器8780A 8780A 8780A
发表于 2010-3-13 17:19:13 | 显示全部楼层 |阅读模式
 8780A 8780A 8780A
联系:邹勤兵/先生(经理)
手机:13168918785
手机:13006600689
手机 18923859098
  QQ:772149346
传真:0755-82403227
E-mail:zqb13168918785@163.com
欢迎来电咨询!期待顾客上门看货!您的满意是我们最终的追求!
备注:本公司长期回收 示波器 网络分析仪 综合测试仪  频谱分析仪  信号发生器 GPIB 等 高频二手仪器
产产品名称: 信号源
品  牌: HP
产品型号: 8780A
产品指标: 10 MHz-3 GHz
产品信息: 8780A vector signal generator is a synthesized IF source with exceptional modulation for modern receiver and component testing. It is capable of modulation bandwidths almost 100 times wider than previous synthesizers. It has built-in mapping to simplify generation of common digital modulation formats. Its extra-wide modulation bandwidth comes from a vector modulator that effectively doubles baseband modulation bandwidths for 700 MHz of output modulation. The vector signal generator′ wideband modulation is complemented with an unmodulated coherent carrier output for demodulation of test signals. The Agilent 8780A vector signal generator offers a wide variety of modulation using both digital and analog inputs. It generates many standard digital modulation formats like QPSK and 16 QAM and traditional modulation like FM, AM, and pulse. By combining the different modulation types, signals as diverse as Barker-coded radar pulses and Doppler-shifted satellite signals can be simulated. The Agilent 8780A vector signal generator is well suited for receiver measurements where wideband or complex modulations are required. It can be used as a calibrated transmitter to test modern radar EW receivers or communication receivers using vector I/Q modulation techniques. It provides a stable, coherent carrier for pulse measurement. It can also be upconverted if receivers operate at frequencies higher than 3 GHz.
特性
10 MHz to 3 GHz IF testing
BPSK, QPSK, 8PSK, 16QAM, 64QAM, digital modulation and pulse
Direct-sequence spread spectrum modulation with chip widths to 7 ns
Pulse modulation with 1 ns rise times
700 MHz modulation bandwidth using I/Q or vector
Wideband FM: over 200 MHz p-p deviations
Optional analog phase modulation for satellite telemetry
GMT+8, 2024-11-17 14:34 , Processed in 0.114231 second(s), 15 queries , MemCache On.
