查看: 1214|回复: 0
Tektronix 1101A有源探头电源
发表于 2009-4-16 17:46:19 | 显示全部楼层 |阅读模式
1101A Power Supply
AC or DC coupling selection is available on the P6201 and P6202A FET Probes. When AC coupled, the DC voltage component is blocked, allowing viewing of superimposed signals.
A self-contained selectable 50 ohm termination switch allows the P6201 or P6202A to be terminated into a 50 ohm or 1 megohm oscilloscope inputs.
Power for the P6201 and P6202A is supplied by the 400 Series, 2400 Series and 7000 Series mainframes through the optional Probe Power Jack or the 1101A Power Supply.
The P6201 or P6202A may also be used with other 50 ohm and 1 megohm input real-time oscilloscopes, sampling systems, spectrum analyzers and counters by using the 1101A and appropriate interface adapters (SMA to BNC, GR to BNC, etc.).
The 1101A power supply provides external power to probes when the oscilloscope used does not have the capability to supply probe power.
The 1101A has two power receptacles that will power up to two independent probes, such as the P6201, P6202A and P6230.
美国泰克生产
联系电话:010-80668458
手机:13701153024
QQ:523948533
GMT+8, 2025-2-2 00:28 , Processed in 0.102863 second(s), 15 queries , MemCache On.
