查看: 1124|回复: 0
视频噪声表UPSF2
发表于 2009-4-16 17:41:37 | 显示全部楼层 |阅读模式
VIDEO NOISE METER
UPSF2
厂商: 德国 Rohde & Schwarz
尺寸: 50x16x47cm
重量: 18 kg
The Rohde & Schwarz Video Noise Meter UPSF 2 measures voltages occurring in transmission systems either in the unweighted mode from 40 Hz to 10 MHz or in the weighted mode with the appropriate filters incorporated.
The video level / chroma noise meter plugin UPSF 2 - E2 supplied with the set affords further measuring possibilities.
- The relevant IEC CCIR specifications are satisfied
- Automatic switch over to 625 line or 525 line systems (dual standard unit) using the standard-dependent filters
- Free choice of test point: full field or any test line
- Measurement of true RMS peak values autoranging over 80 dB
- Alphanumeric readout of measured value operational status.
联系电话:010-80668458
手机:13701153024
QQ:523948533
GMT+8, 2024-12-20 14:53 , Processed in 0.113049 second(s), 15 queries , MemCache On.
