高分辨技术领导者松下公司30日发布下一代高分辨率1080p蓝光播放器---DMP-BD30!
DMP-BD30是首部标准轮廓蓝光播放器,许多新式以及增强型功能让这款松下新品在蓝光竞技场上脱颖而出。其中包括DMP-BD30独有的SD存储卡插槽,不仅可以用来存储录制的高分辨率内容(AVCHD格式),还能用来预览存储在SD卡中的静态数码照片。
Final Standard Profile is an advanced function added to the Blu-ray standard, which opens the door to new functions such as Picture-in-Picture (which displays a second image in a sub window) and Audio Mixing (allows the consumer to switch the sound between the main and sub windows).
“The DMP-BD30 will contribute greatly to Blu-ray’s mounting lead over the competing format,” said Gene Kelsey, Vice President, Panasonic Entertainment Group. “Panasonic’s adoption of the Final Standard Profile adds a whole new dimension to the entertainment experience. For example, when the added value features inherent to the Final Standard Profile are incorporated into a Blu-ray movie, the viewer could have a myriad of entertainment options. One of the more intriguing aspects of the Final Standard Profile is the Picture-in-Picture feature that would allow the movie fan to access a variety of entertainment enhancements, such as having the director or an actor pop up to discuss a scene you are watching, or with an animated movie, you might see the actor performing their character’s voice over, all while still watching the movie. Not only do these features give Panasonic a strong advantage in the high definition market, but they provide the movie community with numerous opportunities to embellish the viewing experience with additional creative elements.”
With an SRP of $499.95, the DMP-BD30 also features a lot of technology advances, including Deep Color Compatibility, and HDMI 1.3B, that bumps the step gradation from 8-bit 256 all the way up to 12-bit, 4,096 step gradation. To further enhance the viewing experience, the DMP-BD30 also provides 1080/24p playback, so the consumer can enjoy the same 24-fps (frames per second) reproduction as the original movie. This eliminates the need to utilize 3.2 pull down, a process to convert 24-fps images to 60-fps, resulting in a smoother picture.
The inclusion of a multi-function SD Card slot is another new addition to the Panasonic Blu-ray player. Coupled with the AVCHD codec, the DMP-BD30 allows for images recorded on a high capacity HD SD card to be outputted directly from the player’s HDMI terminal in their original 1080p form. To further benefit the user, the DMP-BD30 provides an AVCHD Direct Navigator function that makes it easy to search for particular scenes. The player can also play back JPEG still images on an SD card, such as those recorded with a Panasonic Lumix digital camera. The DMP-BD30 converts the images to 1920x1080 resolution, ideal for viewing on a1080p HD Plasma and output them through the HDMI terminal.
Like its predecessor, the DMP-DB30 features the EZ-Sync HDAVI Control that allows the consumer to operate their Panasonic home theater system with one remote. With one touch of the EZ-Sync button, all the components turn on, the correct TV input is chosen, the TV’s built-in speakers are muted and the home theater starts playback. |
