查看: 2975|回复: 0
BCR108:NPN Silicon Digital Transistor什么意思?
发表于 2008-7-15 22:48:38 | 显示全部楼层 |阅读模式
? Switching circuit, inverter, interface circuit,
driver circuit;
? Built in bias resistor (R1=2.2kΩ, R2=47kΩ);
? For 6-PIN packages: two (galvanic) internal isolated transistors with good matching in one package。 怎么用呢?如果用它来驱动用作电源指示灯的发光二极管,干么不直接用FPGA的IO口驱动呢?
GMT+8, 2025-1-9 03:10 , Processed in 0.109912 second(s), 15 queries , MemCache On.
