查看: 3205|回复: 1
富士通推出第一个4通道HDMI连接端口
发表于 2007-11-15 16:20:03 | 显示全部楼层 |阅读模式
from www.physorg.com
富士通推出过实际上第一个用于数字电视的嵌入式FRAM,可以同时支持4通道HDMI连接端口。这种创新可以减少元器件数量、占板面积以及编程的工作成本,可望降低数字电视的成本。
Fujitsu Introduces First 4-Channel HDMI Connector Ports
by Mary Anne Simpson
Fujitsu has introduced the world´s first embedded FRAM for digital TVsthat allow simultaneous use of a 4-Channel HDMI connector ports. Theinnovation will reduce the number of pars, mounting space andprogramming labor costs. It is expected to reduce the costs of digitalTVs.
In a blink of an eye Fujitsuhas solved the costly problem of having to have separate memory on eachof the HDMI ports. Fujitsu has produced the first embedded FRAM fordigital TV that allows simultaneous use of a 4-Channel HDMI connectorports. The HDMI connector ports are used for running DVD recorders,camcorders, video [size=100%]gaming consoles, that store high resolution data and are read by audio visual devices when used with digital televisions.
In use the new Fujitsu LSI indigital TVs allows high-speed factory programming of Expanded DisplayIdentification display data. This breakthrough provides a cost savingin the overall production by reducing the number of the parts andreducing mounting space.
In practice the evolution in HDMI, a digital multi-media interfacehas created high-quality video and audio output. The HDMI connectorwhen used allows devices that create output to read the display data,like the display resolution and then automatically adjusts their outputto produce the best display. The memory function for display deviceswhich need four EPROM cells can now be handled by one cell.
The key specifications are a memory capacity of 256-byte. Theinterface is DDC 4-Channel. The package is TSSOP 16-pin. The keysavings besides parts and space is the reduced labor costs involved inthe factory programming process. In turn this will potentially reducethe costs of producing digital televisions.
Fujitsu is a leader in the field of IT and communication solutionsheadquartered in Tokyo, Japan with offices around the world. Fujitsuplans to demonstrate and show the innovation named MB85RF402 at theEmbedded Technology Trade Show on November 14-17, 2007 in Yokohama,Japan. It is currently available for sample shipments and has a millionunit per month sales target.
发表于 2007-12-28 18:22:14 | 显示全部楼层
回复:富士通推出第一个4通道HDMI连接端口
原帖由新闻我最牛于2007-11-15 16:20发表:
Fujitsu has introduced the world´s first embedded FRAM for digital TVs that allow simultaneous use of a 4-Channel HDMI connector ports. The innovation will reduce the number of pars, mounting space and programming labor costs. It is expected to reduce the costs of digital TVs.
In a blink of an eye Fujitsu has solved the costly problem of having to have separate memory on each of the HDMI ports. Fujitsu has produced the first embedded FRAM for digital TV that allows simultaneous use of a 4-Channel HDMI connector ports. The HDMI connector ports are used for running DVD recorders, camcorders, video [size=100%]gaming consoles, that store high resolution data and are read by audio visual devices when used with digital televisions.
In use the new Fujitsu LSI in digital TVs allows high-speed factory programming of Expanded Display Identification display data. This breakthrough provides a cost saving in the overall production by reducing the number of the parts and reducing mounting space.
In practice the evolution in HDMI, a digital multi-media interface has created high-quality video and audio output. The HDMI connector when used allows devices that create output to read the display data, like the display resolution and then automatically adjusts their output to produce the best display. The memory function for display devices which need four EPROM cells can now be handled by one cell.
The key specifications are a memory capacity of 256-byte. The interface is DDC 4-Channel. The package is TSSOP 16-pin. The key savings besides parts and space is the reduced labor costs involved in the factory programming process. In turn this will potentially reduce the costs of producing digital televisions.
Fujitsu is a leader in the field of IT and communication solutions headquartered in Tokyo, Japan with offices around the world. Fujitsu plans to demonstrate and show the innovation named MB85RF402 at the Embedded Technology Trade Show on November 14-17, 2007 in Yokohama, Japan. It is currently available for sample shipments and has a million unit per month sales target.
我正在做hdmi   欢迎探讨   376193764
GMT+8, 2025-1-8 06:38 , Processed in 0.118732 second(s), 17 queries , MemCache On.
