2回答
0收藏
美国线规 -1- 裸铝电线
#开发软件 #开发软件 11827 人阅读 | 2 人回复 | 2007-07-03
AWG Cable Description
American Wire Gauge
The table below lists the Aluminum wire Characteristics for different gauges of the American Wire Gauge [AWG]. The American Wire Gauge provides a means of specifying wire diameters. For each different AWG [wire size] the table provides the Diameter [in mils], Diameter [in Circular mils], the resistance per 1000 foot, the Fusing current, and Pounds per Foot [number of feet required to weigh 1 pound]. Read the notes below the table to determine how the Ampacity was derived. The larger the AWG number, the smaller diameter wire. The table is based on an ambient temperature of 25oC. Conductor size is based one or more of the following considerations:
Current carrying capacity [inducing a rise in wire temperature, in high-voltage lines], Short circuit current, or Voltage drop [long low voltage lines].
AWG Aluminum Wire Table AWGDiam. (mils)Circular milsOhms/1000ftFusing CurrentPounds/1000ft00004602120000.0804-195.00004101680000.101-154.0003651330000.128-122.00324.851050000.161-97.01289837000.203-76.92258664000.256-61.03229526000.323-48.44204417000.408-38.45182331000.514-30.46162263000.648495.024.17144208000.817416.019.18128165001.03349.015.29114131001.30299.012.010102104001.64247.09.55119082302.07207.07.57128165302.61174.06.01372.051803.29146.04.76146441104.14123.03.78155732605.22103.02.99165125806.5988.802.37174520508.3172.901.881840162010.561.401.491936129013.251.601.182032.0102016.743.200.9392128.581021.0-0.7452225.364226.530.500.5912322.650933.4-0.4682420.140442.121.600.3712517.932053.1-0.2952615.925467.015.200.2342714.220284.4-0.1852812.616010610.700.1472911.3127134-0.1173010.01011697.5800.0924318.979.7213-0.0733328.063.22695.3200.0581337.150.1339-0.0461346.339.84283.7900.0365355.631.5540-0.0290365.025.06812.680.0230374.519.8858-0.0182384.015.710801.850.0145393.512.51360-0.0115403.19.917201.310.0091
Table of Bare Aluminum Wire
Notes:
The table above only lists the AWG standard. The wire size is different between the American Wire Gage [AWG] and the British standard.
AWG [American Wire Gauge] may also be called the Brown and Sharpe (B&S) Wire Gauge.
The Birmingham Wire Gauge [BWG] is used for steel armor wire.
Watch for round-off errors, as many numbers were rounded. Use the table as a guide.
The weight does not include wire insulation. The weight of the wire is critical in some applications.
Circular mils is the diameter squared in mils.
The wire fusing [melting] current is based on the material the wire is made of, the diameter of the wire and the melting point of the the material. The wire fusing current of a wire is provided in tables as constant current or as [a larger] current for some given amount of time.
I found this formula used on a few different sites [un-verified]; I=Ad(3/2) @ d is in inches, A is a constant: A = 10,244 for Copper. A = 7,585 for Aluminum.
I have listed a number of values for fusing current in the table above, for selected AWG sizes.
Copper wire properties are listed under on the Copper electrical Wire page
Manufacturers listing for electrical Wire and Cable {This Web Site}
Refer to the How to Derate Components page for derating wire with other then Teflon insulation
Refer to the National Electrical Code [NEC] to determine cable sizing for premises wiring. This page represents my notes on the subject, purchase one of the standards or specifications referenced on this page when doing professional work.
Also see the Wire Insulation Color Code page; Color coding of wire insulation based on application.
Key words: American Wire Gage, AWG, Bare Aluminum wire, Ampacity, Fusing, Brown and Sharpe (B&S), Electrical Wire Sizing.
回答|共 2 个
beetleone
发表于 2008-4-18 13:39:24 | 只看该作者
RE:美国线规 -1- 裸铝电线
谢谢!
zbhtzp
发表于 2008-6-7 12:35:14 | 只看该作者
RE:美国线规 -1- 裸铝电线
谢谢版主与大家分享你的精彩内容
